Coolant 212 at idle?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Jan 8, 2024.
  1. Jan 8, 2024 at 2:31 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    It's 65 degs outside with light constant rain. If I let my truck idle for a few minutes with the AC on the coolant temp rises to 212 and stays there. That seems high to me? Once I start driving it drops down to 195-200. For it being so cool outside that seems high to me?
  2. Jan 8, 2024 at 2:45 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    My water cooled motorcycle will get up to 220 at idle. Ambient temp will affect the time it takes coolant temps to rise and fall, but at idle it'll hit its target temp and stay there.
  3. Jan 8, 2024 at 2:55 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That would be high for my 2nd gen that comes with a 180 degree thermostat and rarely goes over 200 while cruising in the summer. Maybe 3rd gen comes with higher thermostat? It could just be a thermostat on a higher temp setting. I remember my oem thermostat would average 205 cruising. Then, went with a Motorad and it averaged 200. Now on my third, an Aisin, and it averages 195. But, with third thermostat, I did a major cooling system overhaul at 200K, also replacing radiator, fan, fan clutch, and water pump, all as preventive maintenance.
  4. Jan 8, 2024 at 3:00 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Why are you concerned with a 212 degree reading?
    BMH and Chew like this.
  5. Jan 8, 2024 at 3:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    Indication that the fan may not be working properly to pull enough air.
    Then driving forces air through and temp drops.
    Your profile shows a 2006. Why are you in the 3g forum with a operational Q?
  6. Jan 8, 2024 at 3:16 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The thermostat has a variable valve lift and set to open more than 8 mm at 212°F.
    So it is normal
  7. Jan 9, 2024 at 9:13 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I just picked up a 2023 3rd gen
  8. Jan 9, 2024 at 9:21 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Since the truck is new to you, have you visually checked the coolant level in the radiator and the reservor?
  9. Jan 9, 2024 at 11:55 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Yes I have, at the running temp it is at the full mark, when it is cold its a little blow the full mark.
    TA2016[QUOTED] likes this.
