Coolant bubbling, overflowing out of overflow tank
Discussion in '1st Gen. Tacomas (1995-2004)' started by jlayden763, Sep 15, 2019.
  1. Sep 16, 2019 at 7:37 AM
    #41
    1997tacomav6
    Denver
    Well my truck has the v6 and has heater hoses above the radiator, this I do know and this OP has the v6 not the 4 banger, hehe
  2. Sep 16, 2019 at 7:45 AM
    #42
    Glamisman
    Glamisman Well-Known Member
    It sounds like the radiator is marginal. I have a post titled "Radiator basics" where I show picture of the top of the radiator that had the exact symptoms that you are experiencing.
    The balance of the system works as designed. The radiator cap holds pressure and then purges when the pressure exceeds the cap design and when the system goes into vacuum it pulls the coolant back in. The fan/clutch mechanism is for cooling below 20 mph-ish where there isnt enough air flow through the radiator core at low speeds to cool the system.
    1997tacomav6 likes this.
  3. Sep 16, 2019 at 7:54 AM
    #43
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    4 bangers have similar hose setup as in heater hoses are higher than radiator and I have had no problem with air in the cooling system/air purge. I have seen T splices done to heater hoses cause head gasket failure and asked the owner what/why? Owner said he was told because the heater hoses are higher than the radiator and wont flush/air purge without them. Cheap plastic fittings auto parts store sold along with flush and fill kits and wrong coolant $75. Head removal, resurface, gaskets, labor $1200.
  4. May 26, 2020 at 10:21 AM
    #44
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    For cooling the engine would it help to run one of those oil filter sandwhich adaptor plates and run your oil thru an oil cooler, to pull excess heat out of engine, seems like running over 6psi of boost generates a ton of extra heat and this could be another way to remove heat. #Air cooled water cooled oil cooled....* mine pushes coolant back and forth on long hill climbs (10- 20 min) even though rpm's are around 3k rpm
  5. Aug 14, 2021 at 12:14 PM
    #45
    awpldlto
    awpldlto Member
    2000 Tacoma v6 auto TRD
    Ive recently started having this issue. Coolant boils out of reservoir only after slow uphill offroad climbs. Long highway drives even over mountain passes, idling for long periods of time in 100+ desert heat, even tried holding my brakes slightly going up steep paved roads and no issue. Seems to only happen when im going slow on uphill and rough sections of trail. Coolant continues to boil over several minutes after engine has been shut off
