Coolant bypass pipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bws2, Jan 2, 2023.
  1. Jun 15, 2023 at 5:49 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "Toyota went back to a stainless steel line sometimes around 2009" and mine's 08 - oh well. Thanks.
  2. Jun 16, 2023 at 8:34 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Mine is a 2012 manual and had the plastic pipe.
    But I have heard of others with 2011 year trucks that got the metal pipe from the factory. Go figure.
    It was just starting to seep a tiny bit behind the water pump before the surgery, evidenced by crusty pink residue from the toyota coolant.
    190k on the odometer at the time.
    Black97v6MT likes this.
  3. Jun 16, 2023 at 8:41 PM
    po35042
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Forgot to mention, I wondered about the new throttle body gasket not having the screen too.
    I installed the new gasket without the screen and the truck has been fine for almost 2 years, noticed no difference.
  4. Jun 16, 2023 at 11:06 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Like I said...."I think":p
  5. Jun 19, 2023 at 6:57 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have an early 2009 and it had the plastic pipe. It didn't leak, but I changed it at ~170k miles. I bought the intake gaskets locally and IIRC I could not find the gasket for the throttle body; I reused it with no issues.
    DGXR likes this.
  6. Jun 19, 2023 at 4:05 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    hmmm never heard of this...I have to top off the coolant every few months...I wonder...
  7. Jun 19, 2023 at 4:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In the reservoir or the radiator?
    I’d pressure test it first.
  8. Sep 3, 2023 at 6:15 PM
    TreeFortRichard
    Brian
    Just looked today when I was working...I have some crust and "wetness" on the bypass connection exiting the radiator connection? at the foreward part of the line...
  9. Dec 11, 2023 at 10:25 AM
    phathead36
    phathead36 Member
    My truck is at dealership and they want $1500 to replace the bipass pipe on my 09 2.7ltr taco which is a lot! Can I delay the repair by keeping the coolant fluid topped up?
  10. Dec 11, 2023 at 2:35 PM
    TnShooter
    Deogee
    STOCK
    I suppose you could, but it depends on how bad it’s leaking. Ideally you want to fix coolant leaks as soon as possible. But there are 1000’s of cars and trucks out there leaking. To each their own.
    Just remember, the cooling system is under pressure. I will leak worse when the truck is on. Which means you won’t see the coolant leak in the driveway like an oil leak.
    So keep an eye on it regularly.
  11. Dec 11, 2023 at 5:31 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    :eek:
    What all are they replacing?! It's a 2 hr job, 3 at the most.
    TnShooter likes this.
  12. Dec 11, 2023 at 5:33 PM
    TnShooter
    Deogee
    STOCK
    Yeah. It’s not near as bad on the 2.7 as the 4.0. Intake off and it’s right there.
  13. Dec 11, 2023 at 5:41 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I did one, it was easy. The worst part is one of the vacuum hoses on the back of the manifold at the rear of the engine is kind of a PITA to get to but once the manifold is off the pipe is right there in the open.
    TnShooter[QUOTED] likes this.
  14. Dec 12, 2023 at 11:49 AM
    phathead36
    phathead36 Member
    I'm getting this done at the dealership currently. Can't tell if the part 16268-75112 that they are ordering is the stainless one because its listed as alloy steel. Anyone help me locate the stainless one?
  15. Dec 12, 2023 at 1:19 PM
    #35
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Also there is lots of information on this bypass pipe replacement elsewhere on TW, search if you need to know more. I am not a professional wrench but I'm pretty handy, did the pipe replacement myself in about 4 hours. Took extra time for photos, labeling hoses, a few notes, etc. Actually it was a fairly easy job, all things considered... just be methodical. I enjoyed seeing into the intake ports and appreciated all the room in the engine bay afforded by the 2.7. I suggest using a small 6-point socket to remove the stud from the head at the very back of the intake, this will make it much easier to connect/disconnect that pesky vacuum hose on the back of the manifold.
    Bizquick likes this.
  16. Dec 12, 2023 at 2:44 PM
    #36
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    That's the part I used but I don't think they are stainless but polished or plated metal although I'm not 100% sure. I think there is only one replacement bypass pipe. I couldn't find any other part numbers when searching.
    I posted photos and part numbers and info on the pipe replacement when I did it here: https://www.tacomaworld.com/threads/2007-2-7l-coolant-bypass-pipe-replacement-info-photos.805019/
    phathead36[QUOTED] likes this.
  17. Dec 12, 2023 at 2:53 PM
    #37
    phathead36
    phathead36 Member
    I'm thinking people may have called it stainless steel cause it looks like it.
    Jimmyh likes this.
  18. Dec 17, 2023 at 2:33 PM
    #38
    Steve_P
    TN
    This is insane. It's an easy job that the average DIYer can do in maybe 4 hours, 6 for sure. Basic hand tools only.
    No one can tell you if you can delay the repair, because it's possible the pipe could catastrophically fail. I think that'd be a remote chance, but....
    If I was you, I'd call a local general repair shop, because this is not a difficult job at all. If you were near me, I'd do it for $300 if you bring the parts and some beer :)
    Black97v6MT and Canadian Caber like this.
  19. Dec 18, 2023 at 9:11 AM
    #39
    TJTM
    TJTM Active Member
    2009 2.7 l, 4x4 access cab
    Fully agree. Did mine in 4 hours and took time to clean the throttle body while it was off. My pipe was brittle at 200,000 KM and broke while it was being removed. It was a problem waiting to happen. The replacement pipe and gasket was less than $150 CDN for OEM parts.
  20. Dec 18, 2023 at 10:19 AM
    #40
    kergilman
    kergilman Active Member
    Kevin
    Tualatin, Oregon
    2009 2TRFE Tacoma SR5 Access Cab
    2" lift, ebay rock crawlers, ebay carpet bedliner
    I just finished replacing the coolant pipe on Sat, also removing the intake manifold and throttle body to clean on my 09 2TRFE w/ 160k, I was surprised to see how dirty that intake manifold is (almost like the bottom of an oil pan)! Used a lot of carb cleaner and shop rags reaching inside as far as I could... Last time I went to Valvoline for oil change they incorrectly closed the air filter houseing leaving a gap in the back...so i was sucking in a lot of dust for a few thousand miles before I noticed...? Now I do my own oil changes...
