Coolant Change Schedule
Discussion in '4 Cylinder' started by Dustyroades, May 31, 2016.
  1. May 31, 2016 at 7:15 AM
    Dustyroades
    Dustyroades [OP] Well-Known Member
    London, Ontario
    2019 TRD Sport
    Just noticed Toyota's service schedule calls for changing the coolant at 128k (km) the first time, and then every 64k thereafter. Why the reduced interval after the first change? Is it OK to let it go further between changes?
  2. May 31, 2016 at 4:16 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I think the shorter maintenance interval (after the 1st service) is because you can't drain it all out. The capacity is 9.1 quarts, and when I did the service, I drained the block and the radiator and I only got about 6 quarts out. So all the coolant is new from the factory and they give you 100,000 miles. But you can't change it all out, so they only give you 50,000 miles after the first service. This may not be the real reason but it makes 100% sense to me.
    This service is cheap and easy so I don't know why you would want to go beyond the recommended service interval. But you probably could get away with it - the engines will outlive the chassis on these trucks.
  3. Jun 4, 2016 at 4:32 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "the engines will outlive the chassis on these trucks." sad but true
  4. Jul 5, 2016 at 6:53 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    take care of it then.
    Abject4x4 likes this.
