Coolant drain and fill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, May 14, 2012.
  1. May 14, 2012 at 7:54 AM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I figure out this is info worth posting here.
    To completely drain and fill on 2gen Tacoma you need 3 gallon jugs of Super Long Life Coolant from Toyota. This is 50/50 diluted and its good up to -34f when its new.
    To completely drain radiator you need one gallon jug of coolant from Toyota.
    Just did drain and fill for radiator.
    Its easy to do.
    1. Park your truck with nose up.
    2. take off front skid plate.
    3. locate drain valve on the radiator. (its on driver side of radiator.
    4. Open top radiator cap
    5. Open drain valve
    6. Close valve as soon the main flow finishes unless you feel Ok with purging air from heater core.
    7. Once coolant is out, poor fresh one in. Fill reservoir to the the full line.
    8. Close radiator cap.
    9 Start truck set heat to max and let it warm up to full temp. Once it does shutdown and wait for it too cool down.
    10 If cool ant in reservoir gets low fill to full line again and start truck again.
    Repeat until coolant stays at full mark in reservoir.
    Sysiphus, MTopp and REDdawn6 like this.
  2. May 14, 2012 at 6:48 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Thanks, I will be doing this in a couple of days but I'm going to use Zerex Asian Vehicle Coolant instead.
  3. May 14, 2012 at 8:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stick with the Toyota coolant unless you are doing a COMPLETE system drain and flush with deionized water.
    There are a number of formulations out there, and incompatibilities can result in serious problems including gelling of the coolant. This is a problem that has plagued GM owners. Toyota coolant is a very similar formula to Dexcool, but it is different enough that gelling and gasket-eating has not been a widespread reported problem.
  4. May 14, 2012 at 8:54 PM
    JayDawg
    JayDawg Christian Pastor. Need prayer,have questions? Ask
    Jay
    Sterling, Co. via San Diego, Ca.
    Tacoma 4x4 Access Cab TRD Off Road Package
    4-PIAA 80 Racing Series Off Road Lights, Randy Ellis Design Light Bar, Bilstein 5100 Shocks, Rear Leaf TSB, Mickey Thompson Classic Lock wheels, fog light mod, more to come...
    When I do my coolant flushes, I also flush the coolant from the motor as well. I never understood if your coolant is dirty, why a person would only drain their radiator but leave dirty coolant in the engine block.
    kidthatsirish likes this.
  5. May 15, 2012 at 9:48 AM
    BlueT
    NorthEast
    Agree to drain coolant from motor if it is dirty. But 6 year old truck should not have dirty coolant. Mine was not, so drain and fill. I don't flush my coolant , I do complete drain and fill only on vehicle I bought with 100k plus miles that had never coolant replaced.
    Normally I do drain and refill every 5-6 years( regardless of miles.)
    5-6 years interval is the same for brake fluid.
  6. May 15, 2012 at 10:30 AM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Guys Im confused. Please clarify...
    Isn't that the purpose of flushing? When you run distilled through the system until it's clear, that gets everything out including the old coolant in the block.
  7. May 15, 2012 at 10:59 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Yes, that's true but more work and costs more. Maybe all that is needed is a drain and refill. It all depends on the severity. If the original coolant is only old but still looks ok then maybe a drain refill is good enough. A drain refill does replace most of it.
  8. May 15, 2012 at 11:22 AM
    BlueT
    NorthEast
    With new coolants and engines you don't want to do "flush" unless you are really in need one (example your head gasket exploded and engine filled with oil/coolant mixture.) Flushing will do more damage then good. Coolants leaves coating inside the engine that protects from rust, lubricates and prevents dirt sticking to walls. Flush will remove coating and new coolant will have to build up the protection.
    Even Toyota manuall tells you to "flush" with coolant only which is drain and fill, drain and fill, drain and fill until clear.
    If you want to clean dirt from coolant line you can remove bottom part of radiator and all the debris will be there. But whole process of resealing radiator is not worth it, I would rather swap radiator for new one.
  9. May 15, 2012 at 11:39 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Are you just draining and filling the radiator? Because there are two other coolant drains on the left and right sides of the engine. When I did my '06 I drained from all 3 and then refilled.
  10. May 15, 2012 at 11:54 AM
    boshak
    AG
    CA
    Thanks for the info!
  11. May 15, 2012 at 1:05 PM
    BlueT
    NorthEast
    just the radiator which is almost half of the coolant. No need to drain Engine unless you know what you doing, have plenty of time to do it right and you have significant mileage on the old coolant.
    Whole thing took maybe 45 minutes top. With drain and refill engine it would have been couple hours to purge air out of the system before you start the truck. Its right thing to do, but if time is not there and coolant is not very bad then radiator drain and fill will do the trick. IMHO
  12. May 15, 2012 at 1:09 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you collect the used stuff? or just let it go? :D
    i hate handling the used stuff. hate it.
  13. May 15, 2012 at 1:15 PM
    BlueT
    NorthEast
    3 times a year we have collection of Hazard Materials so things like coolant, brake fluid ends up there. Next one is this weekend so I am doing all the changes this week so I can ditch my stuff at collection time. :D
  14. May 15, 2012 at 1:20 PM
    boshak
    AG
    CA
    Just put the old stuff into your empty bottles. Look up your local hazardous waste website and drop it off at a monthly event along with your oil. Easy! :)
  15. May 15, 2012 at 2:04 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    My truck was about two years old with around 20k miles. Drained the entire cooling system, including draining the engine on the left and right side. Also, take a close look at how the coolant line is connected to the heater core by the firewall, this can trap coolant.
    Once drained, I filled the entire system with DI water and no coolant, then ran it until for several minutes. Drained it complete again. Refilled with Zerex and DI water @ 50/50.
    FWIW, a lot of crap came out of the oem coolant into the clean catch bottles. The Zerex is cheaper, easier to obtain and while not pink it is an approved coolant.
    Also, my truck has always had a lingering coolant stink after shutdown. The wifes Corrolla suffers from this also. With the Zerex, the linger smell and slow loss of coolant is far less to the point of basically a non issue.
    The one remaining oem fluid in my truck is the brake fluid. That will be flushed and replaced with new very soon.
    Each change away from oem has made the truck improved.
    PK
  16. May 15, 2012 at 4:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's not a matter of "dirty"... it's a matter of the coolant losing effectiveness as it ages.
    Now, most of us do not need freeze protection down to -34, and if our thermostat and the rest of the cooling system is up to snuff, we don't even need boil protection above 210 degrees.
    So while draining and refilling does remove some "gunk", it is primarily "freshening" the coolant.
    Done annually, it is more than adequate to maintain adequate protection and keep clean coolant in the system, considering that the vast majority of vehicles on the road have NEVER had their coolant replaced.
    a400ryan likes this.
  17. May 15, 2012 at 4:54 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Change interval is 10 Years/100K for first change and 5 years/50K from there out.
  18. May 15, 2012 at 5:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup.
    So if you do a radiator drain/refill once a year for the $20 it'll cost, it's something you never have to worry about.
  19. May 15, 2012 at 6:03 PM
    Asgard
    The Zerex Asian Vehicle coolant is pink. I changed my brake fluid and power steering fluid also. Brake Fluid was Valvoline Synthetic Dot 3 & 4. For power steering fluid I used Valvoline Max Life Dex/Merc ATF.
    DyegoPC23 likes this.
  20. May 15, 2012 at 8:52 PM
    PMK
    Florida
    10 DCLB TRD Sport
    My bad, I was thinking Zerex, brain farted, what I used was really Peak Global.
    PK
