coolant exchange cost?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nra4usa, Jul 26, 2025.
  1. Jul 26, 2025 at 12:43 PM
    nra4usa
    nra4usa [OP] Well-Known Member
    Central PA
    2016 Tacoma Sport 4x4 White 4 dr
    So far, just a Hard Hat tonneau cover. Looking for mud guards and nerf boards.
    How much should I expect to pay for a coolant exchange? Not just drain the radiator, but a full exchange.
  2. Jul 26, 2025 at 12:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    As far as I know no shops really do a flush with a flush machine anymore - the type that hooks up inline at the radiator hose and you exchange with the engine running.. but i could be wrong
    I usually just drain the radiator and block and refill it. If your shop doesn't want to touch block drains find a better shop
    Flushes are kinda a throwback to older cooling systems that had sludge problems. Like Chevy and their dexcool problem back in the 90s and 2000s..
    Chew likes this.
  3. Jul 26, 2025 at 1:10 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    It’s a very easy diy job. 2 jugs of coolant, a 2ft piece of clear rubber hose, and I believe it’s a 10mm for the block drain bolt is all you need. $50-60 and an hour of your time will handle it
    Look up Tyler’s (“Team oil Drop”) video on YouTube, he’s got a good video of the job.
    Flush isn’t needed, you’ll get 90% of it out doing the DIY method.
  4. Jul 26, 2025 at 6:42 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Yes watched that video recently, you also need a radiator funnel and the plug for it
  5. Jul 26, 2025 at 6:50 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Prices are all over, location is a large factor, Hawaii is going to be much much higher than rural America. Try the regional sub forum for actual price comparisons.
    BillF1564 and xBloodxLinex like this.
  6. Jul 27, 2025 at 3:30 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Find someone in your area and reach out for an exact price.
    Chew and Greg-tacoma like this.
  7. Jul 27, 2025 at 3:37 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Toyota made changing the coolant very easy.
    I perfer to use Toyota branded coolant, the dealer sells it for a reasonable cost. It takes 2 gallons to do a full service.
    Get some 5/16" ID hose, it fits the radiator drain too. If you leave the radiator cap on when you drain the radiator (before draining the block) it will siphon the fluid out of the recovery bottle too.
    After you have got all you can from the radiator, draining the block is easy, now remove the radiator cap.
    Remove the passenger wheel, pop the top plastic clip out and gently fold the splash shield down.
    And find this handy block drain.
    A long extension and a 10MM socket.
    The coolant won't gush out, just get it draining and go do something else for a while.
    Fill it up nice and slow, keep squeezing the top radiator hose to work the air out.
    Double check/top up the level in the recovery bottle after a few days.
