Coolant Filter - Best Location/ line Selection?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crtx, Jan 22, 2020.
  1. Jan 23, 2020 at 7:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lol of course its a jeep thing. I could see it being beneficial on an old iron block'd / head motor.... but an aluminum block / aluminium head motor like our 1GR with proper coolant pointless.
    I also question the effectiveness of any sort of loop like the one in the OP where fluid isnt actually forced through the filter, i bet there is hardly ANY flow through the filter like that.
    crtx[OP] and Muddinfun like this.
  2. Jan 23, 2020 at 11:53 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I applaud a person who attempts something new. However this is unnecessary.
    crtx[OP], Muddinfun and nd4spdbh like this.
  3. Jan 23, 2020 at 12:30 PM
    Skynet Surfer
    Skynet Surfer Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    Interesting idea but where to put it indeed. As well how effective would it really be. Not exactly looking to add weight if it's not going to give a solid reason to do so. Granted I think the interval for flush is 100k service?
  4. Jan 23, 2020 at 4:51 PM
    crtx
    crtx [OP] Well-Known Member
    I was thinking the same thing. I can't imagine much flow is being directed through the filter. At the same time, that is a direct result of it being a bypass system.
    I'm far from a fluid expert, but slower flow through the filter could allow for better filtration. No idea though.
    I don't see it adding much weight. At most, 5 pounds?
  5. Jan 24, 2020 at 8:21 AM
    nd4spdbh
    SoCal
    Speed of fluid though such a filter wont make a difference, the amount of fluid will though. Honestly that bypass pipe just looks like snake oil to me.
    crtx[QUOTED][OP] and Muddinfun like this.
  6. Jan 24, 2020 at 8:39 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    So when the filter media fails or collapses in on itself and doesnt allow coolant through anymore and you overheat your engine, what are you gonna do?
    Imo, this is introducing a new failure point in the cooling system. And if there is a bypass around the filter, then whats the point of doing this at all?
    jbrandt likes this.
  7. Jan 24, 2020 at 9:21 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Interesting idea...however I have never seen cooling system issues that are caused by sediment. Every cooling system issue I have seen is due to corrosion (likely because regular maintenance was not performed) or physically broken parts like an end tank or hose gone bad.
    If a coolant flush is performed every 100k (or what you feel is necessary) you'll be fine. I cannot comment on desert cruising though as there is a lot of dust, that may have different impact if say your coolant reservoir cap falls off or something or the vehicle is involved in a flood.
    crtx[OP] likes this.
  8. Jan 24, 2020 at 10:43 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I would put in heater core lines.
    I have thought about one for my F350 but a new water pump is already on it and some like the heater core method since it wont stop the floe
  9. Jan 24, 2020 at 10:45 AM
    knottyrope
    Knotty
    Bahstun
    Ford 7.3 had a lot of sand in the blocks even after factory flush. If you dont clean them then the water pump life is poor.
    my lower hose was half plugged with sand and gunk
  10. Jan 24, 2020 at 10:48 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Waste of time and money
  11. Jan 24, 2020 at 10:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you have crap building up in your coolant system that needs to be filtered out, you have other problems that need to be addressed. A filter doesn't fix anything.
    I see no reason to add another potential point of failure to a cooling system.
    nd4spdbh and Blue92 like this.
  12. Jan 24, 2020 at 12:16 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I guess it couldn't hurt... just an added complication to worry about but you addressed that with "if done correctly" so good luck.
    Personally I would choose the heater core hose since that's pretty easy to access and the heater core is a non-essential system.
    Also because the heater core is just a small radiator and more likely to build-up particulates, if there are any, moreso than the radiator I'd imagine.
  13. Jan 24, 2020 at 12:38 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    About Waterless Coolant Traditional engine coolant is 50% water, but water causes engine corrosion and overheating. Evans Waterless Coolant is a glycol-based fluid that contains no water, so it eliminates many of the problems of water-based cooling systems.
    https://www.evanscoolant.com/how-it-works/
  14. Jan 24, 2020 at 12:45 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Coolant filter? What the actual fuck?
    Sounds like bullshit being sold to "solve" a problem that doesn't exist.
    Change the coolant as per the recommended intervals, with the proper fluid and call it a day. You are NOT going to have massive amounts of shit in your coolant system... I don't care what some dude on I hate mud or Pirate Offroad says.
    And if you do... have a bunch of shit in your coolant system... and you put a filter in it... filters clog.
    Having a clog in your coolant system is no bueno.
    Guess why none of the manufacturers put this garbage in their vehicles.
  15. Jan 24, 2020 at 4:52 PM
    #35
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Who is Floe and why would you want to stop her?
  16. Jan 24, 2020 at 5:08 PM
    #36
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Heater cores and radiators in Toyota trucks and SUVs typically fail by external leaks. The plastic portion of radiators tend to embrittle and crack. In 3rd gen 4Runners, the radiators leaked internally, allowing coolant to contaminate the transmission fluid. Neither issue would be addressed by a coolant filter.
    crtx[QUOTED][OP] and Skyway like this.
  17. Jan 24, 2020 at 10:07 PM
    #37
    crtx
    To address the clogging statement- thats the point of the bypass system. If it were to be clogged, it would not effect the flow of the coolant, as the main line is still flowing live and well.
    And that is incorrect, multiple manufactures sell engines where coolant filters come stock. Very common in the fleet world, especially on diesel engines.
