Coolant flush**RESOLVED**
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998 TACO24, Apr 14, 2023.
  1. Apr 14, 2023 at 4:47 AM
    1998 TACO24
    1998 TACO24 [OP] Well-Known Member
    Bud
    So I did a coolant flush last night, ran 4 gallons of distilled water though the truck and everything went well till the end. I noticed the heater was not putting out heat like it was during the first and second flush. I proceeded to add the coolant as the last step and still not much if any heat. I let the truck idle for at least 30 mins with the radiator cap off and saw no bubbles in the opening. I continued to squeeze the hoses to verify there air was out of it. Again no bubbles. After researching the issue on this site and a couple others, some suggested raising the truck up off the ground. I did that, no difference. I then felt the hoses that run to the heater core, the ones before and after the heater valve were warmish. Not as hot as the radiator hoses. The long one coming out of the heater core was not hot at all. So my guess is the core is blocked and needs to be back flushed? Any help would be awesome.
  2. Apr 14, 2023 at 5:12 AM
    1997tacomav6
    Denver
    I doubt the core is plugged,
    The heater core lines are higher than the radiator cap so even when you fill the radiator to full it’s still not getting to the heater core.
    You need the radiator fill kit funnel that adapts to the radiator cap that changes that by another foot higher
    Area51Runner likes this.
  3. Apr 14, 2023 at 5:15 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  4. Apr 14, 2023 at 5:18 AM
    1998 TACO24
    Bud
    I tried to use one of those. It leaked like crazy...it sealed around the radiator but where the funnel went into the adaptor it leaked bad. So I just poured the coolant in with another funnel.
  5. Apr 14, 2023 at 5:28 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    If you had a cheaper version buy a lisle ones, they are better quality. Another option would be to elevate the front end drastically, be it parking on a hill or jacking the front end up. Have you just let the truck idle or have you revved the engine up and held it there for a little bit to really get the coolant moving?
  6. Apr 14, 2023 at 5:29 AM
    Area51Runner
    They work, make flushing the system so much easier. I'd try the Lisle. Like everything else, there will always be cheap knock-offs. Make sure you're using the correct attachment piece. Not sure about the one you tried before but the Lisle comes with multiple attachment options.
    Another thought is its not the funnel but something is seriously WONKY with your cooling sys and you have a real issue. Hopefully not.
    :fingerscrossed: you sort it out. G/L
  7. Apr 14, 2023 at 5:32 AM
    1998 TACO24
    Bud
    I have not done that. I'll try another brand of the funnel and see if that works.
  8. Apr 14, 2023 at 5:32 AM
    1998 TACO24
    Bud
    Mine was the SEDY brand.
  9. Apr 14, 2023 at 5:38 AM
    Area51Runner
    Before you pick up the Lisle, maybe do another review of the process used with yours. Maybe you missed something. :notsure:
    Entirely possible.
    System has to be burped good for it to function correctly. If you still have air pockets in there, going to cause funky behavior.
  10. Apr 14, 2023 at 5:49 AM
    1998 TACO24
    Bud
    Possible. But I'm pretty careful when doing stuff. Plan it out and then execute it lol But I will go over everything tonight again and see if I did miss something.
    Area51Runner[QUOTED] likes this.
  11. Apr 14, 2023 at 6:37 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    How old is the thermostat? Will be interesting to see what you come up with. I recently did this on my 98 3.4 and didn't have any issue. It almost blows too hot now.
  12. Apr 14, 2023 at 7:01 AM
    1997tacomav6
    Denver
    Here in another opinion that I did.
    I added a prestone flush filler T at the input line of the heater core line,
    That way you can top it off from there and this is the highest point now and you will have no air trapped
  13. Apr 14, 2023 at 7:05 AM
    1998 TACO24
    Bud
    It all worked fine before the flush. The radiator and the T Stat were changed about 4 years ago. The temp gauge was working fine the whole time i was doing the flush. I am leaning to the cause being air in the system.
    Xbeaus[QUOTED] likes this.
  14. Apr 14, 2023 at 7:16 AM
    Xbeaus
    Beau
    Kind of sounds like it. Sometimes the air can be pretty stubborn
  15. Apr 14, 2023 at 7:21 AM
    1998 TACO24
    Bud
    If that stupid funnel would of sealed, I'm sure I would not be having this issue. :facepalm:
  16. Apr 14, 2023 at 7:30 AM
    Xbeaus
    Beau
    Probably right. Might of got a lot of air in there. Like someone else said jacking the front up will help. Leave it sit over night with the cap off. Sometimes this helps burp some of that air out.
  17. Apr 14, 2023 at 7:33 AM
    1997tacomav6
    Denver
    I’ve never had leaking issues with the lisle model
  18. Apr 14, 2023 at 8:00 AM
    1998 TACO24
    Bud
    Yeah. I'm thinking it maybe the after market rad that was installed years back? It leaked from the adaptor area. It was a mess!
  19. Apr 14, 2023 at 12:51 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    i have a spill proof funnel and has worked on every car i own. might not fit my 2021 4 runner but i haven't had to flush the radiator in that thing yet.
  20. Apr 14, 2023 at 2:38 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    How are you doing the flush? Did you have the heat control cranked to full hot and set it at the highest fan setting? I always flush with the rear wheels on ramps and refill with front wheel on ramps. Never had any issues. If all else fails then you can use a tool like the Airlift to pull a vacuum to refill. I've done both ways but pretty much just fill and burp now since I hate bringing out the compressor.
