Coolant flush safe?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Feb 25, 2016.
  1. Feb 25, 2016 at 10:31 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Starting my t-belt/waterpump job in the morning. I think I want to flush the system today though to cut time tomorrow. The paranoid guy in me is wondering if the prestone coolant flash chemical you buy is harmful in anyway to the gaskets or seals in the motor. I'm not talking about immediate harm but more like does it cut the lifespan of gaskets and seals it's come into contact with.
    I guess I'm looking for horror stories with the prestone type flush stuff. Anyone?
  2. Feb 25, 2016 at 10:35 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    When I changed my timing belt/water pump and radiator (two separate incident), I just drained (not flush), do the work and filled with fresh red coolant mixed with distilled water. I don't think a true flush is needed unless you're switching to green coolant afterwards.
    NAAC3TACO likes this.
  3. Feb 25, 2016 at 10:35 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If your coolant is in good condition now, I would just flush it with fresh, clean water. The Prestone flush is what GM had us use to clean out the contaminated S10 cooling systems years ago. We had no side effects using this product.
