Coolant flush
Discussion in '1st Gen. Tacomas (1995-2004)' started by Floridaguy99, Aug 11, 2017.
  1. Aug 11, 2017 at 12:53 PM
    Floridaguy99
    Floridaguy99 [OP] New Member
    2000 Tacoma Prerunner
    So I just bought a 2000 Tacoma Prerunner recently and I noticed the coolant was green. I thought the right color was the red Toyota long life stuff, so i decided i was going to flush the system and put the red stuff in. I added the prestone coolant flush a few days ago but according to the dealership Toyota used green ethylene- glycol antifreeze and they said it's fine and I don't need to worry about it. But my question is about the coolant flush i put in, is it safe to leave it in there until i change it later down the road?
  2. Aug 11, 2017 at 1:11 PM
    NM Lance
    NM Lance Well-Known Member
    I probably wouldn't leave the coolant flush in. It may cause corrosion and eat up your hoses. What type of flush did you use? I use straight white vinegar and it seems to work wonders.
  3. Aug 11, 2017 at 1:11 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Should be fine. At least it's not yellow or brown
  4. Aug 11, 2017 at 1:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What does Preston recommend?
    Dalandser likes this.
  5. Aug 11, 2017 at 1:21 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This x2. Call the manufacturer and they will provide you with a good answer.
  6. Aug 11, 2017 at 1:52 PM
    Floridaguy99
    I tried calling them but customer service is closed for the day. Out of luck there until Monday.
  7. Aug 11, 2017 at 1:55 PM
    Floridaguy99
    I used Prestone Radiator Flush and Cleaner.
  8. Aug 12, 2017 at 7:57 PM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    Cheap enough- I would not risk it. Swap it out since the flush is in there.
