Coolant gauge pegged above H, but not overheating.
Discussion in 'Technical Chat' started by gogrizgo01, Apr 2, 2020.
  1. Apr 2, 2020 at 4:28 PM
    gogrizgo01
    gogrizgo01 [OP] Member
    Gharrett
    Dursma
    Hey everyone.
    I am new to the Tacoma world, just bought an 04 Toyota Tacoma, 4 door with the V6 3.4L Engine. My issue is when I first start the engine in the morning, cold start, temp gauge on the dash shows cold like it should. However after 1-2 minutes of warming up, will spike up above the H and stay there. However the engine is not over heating, everything working as it should, and not getting incredibly hot. Im assuming this is a bad temp sensor? I've found there are two, one on the front, which goes to the comp, and the one on the back that goes to the gauge. Had our electrician tech at work test the sensor and the ohms steadily declined until it ultimately hit zero. He was expecting it to just drop to zero at some point, since the gauge jumps from C to H. But it didn't, however it still hits 0 even though it is not over heating. Am I looking at a bad sensor here? Just don't want it to be a bad gauge because that involve the dash cluster. Any advice is helpful. Thanks!
  2. Apr 2, 2020 at 4:33 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Welcome!
    Not with my Tacoma but I had this issue long ago with a car. The temp sensor did the trick
    gogrizgo01[OP] likes this.
  3. Apr 3, 2020 at 8:15 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I’d say most likely the sensor. I had a similar prob on a Ford truck and it was the sensor.
  4. Apr 3, 2020 at 1:37 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Another vote for the sensor. Was pretty cheap on a Mazda I used to own, and easy to change.
  5. Apr 23, 2020 at 1:06 PM
    gogrizgo01
    Gharrett
    Dursma
    Okay so I have replace both sensors. The ECT at the front of the engine, and the gauge sensor at the back. Temp gauge still climbs up to H after 2-3 min on a cold start. Engine still runs fine, no steam, no fan running overtime. Bad gauge or resistor in the gauge?
  6. Apr 23, 2020 at 1:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would check the wiring to the cluster. Are the other gauges behaving?
  7. Apr 23, 2020 at 1:14 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Cheap Chinese sensor.
  8. Apr 23, 2020 at 1:15 PM
    gogrizgo01
    Gharrett
    Dursma
    Yea Fuel, speedo and tach all working as they should.
  9. Apr 23, 2020 at 2:12 PM
    0xDEADBEEF
    If you have a multimeter, I would check what voltages you're getting at the sensor. There should be a spec somewhere.
  10. Apr 23, 2020 at 2:27 PM
    gogrizgo01
    Gharrett
    Dursma
    I do have CEL on and its throwing code P0118 "Engine Coolant Temperature Circuit High Input". But you would think switching both sensors would fix that. Unless its something in the harness not connected?
    Me and a buddy ran the coolant temp on his OBDII and its sitting at the correct temp, so definitely not overheating.
