Coolant Leak - 2017 TRD OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSRQ, Jan 27, 2023.
  1. Jan 27, 2023 at 12:55 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    I have a 17’ TRD Sport. Noticed that my coolant bypass was leaking early last year(don’t remember the exact mileage but under 70k at this point). I have the “platinum warranty”. Took it into Toyota. Had to physically go out under my truck that was up on a lift and show the tech where it was leaking from. They quoted me right under $2k to replace it. Service manager told me to open up a case with Toyota. A couple days later and a few phone calls with Toyota corporate, they told me they will cover $1300 and I’ll have to eat the rest. The “platinum warranty” has specific verbiage that states it does not cover “coolant hoses”. Was what it was. Had my truck back a few days later.
    MGMDesertTaco and shakerhood like this.
  2. Jan 27, 2023 at 1:06 PM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    Was that problem remedied in later models? Does anyone know if they changed something to prevent this? Someone posted it hasn't been happening in later model years but maybe just not yet.
  3. Jan 27, 2023 at 1:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So, you paid about $700 after it was all done?
    Darksport[QUOTED] likes this.
  4. Jan 27, 2023 at 1:08 PM
    Darksport
    Jake
    NE Ohio (Cleveland)
    Yep. Right around there with tax.
    tonered[QUOTED] likes this.
  5. Jan 27, 2023 at 1:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    Thanks for the info.
  6. Jan 27, 2023 at 1:13 PM
    TacoSRQ
    TacoSRQ [OP] New Member
    Brooks
    Yeah.. you guys all hit that on the head. Looks like that's exactly what it is. Coolant bottle is indeed low. Picking some up coolant tomorrow to feed the leak until I get some time to fix it. Not seeing any write ups on a DIY yet? But if it's just taking off the intake plenum and exercising some patience, I'm in.
    And thank you all for the knowledge!
  7. Jan 27, 2023 at 1:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    There were various paths noted to tackle this. For example, some dealers pull the engine mounts and tip the engine down. It can also be accessed with the transmission removed. I'll take a peak to see what the SM says.
    But, pulling the intake sounds like the easiest route. You can find that info in the SM for the spark plug replacement. But interestingly, the plugs can be changed without touching the plenum. Haha!
    Edit: There's nothing that I could find in the SM for this replacement. The SM that we have is not complete, so it could just be a missing part?
  8. Jan 27, 2023 at 7:02 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Removal and installation is in the engine mechanical section, engine unit disassembly/reassembly. BUT it assumes the engine is out of the truck.
    If you look in the engine control section, to remove the coolant temp. sensor which is in that stupid by-pass pipe, step 1 is to remove the intake manifold. So yanking the surge air tank and intake manifold seems to be a possible way to get to it.
  9. Jan 29, 2023 at 5:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The part was updated for the 2020 model year last I checked. Nobody really knows what changed but the part was definitely updated and superseded. I would assume it was to help protect against the issue. I’ll try to find the part numbers again.
    Original: 16356-31050
    Supersession: 16356-31051
    happened somewhere between 2018 and 2020. I can’t find it but I know I found it before. I have not seen anyone with about a 19 or later have any issues so I would assume whatever they did fixed the problem.
    edit: I see further along in my reading you are already aware of the part number change.
  10. Jan 29, 2023 at 6:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All good!
    Hopefully that is the solution.
    BLtheP[QUOTED] likes this.
  11. Jan 30, 2023 at 9:20 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    The warranty states this does not cover 'hoses".
    But this is not a hose, it is a pipe, so I wonder why it is not covered ??? :confused::confused::confused:
    Lt. Dangle, airmax233 and shakerhood like this.
  12. Jan 30, 2023 at 9:51 AM
    MGMDesertTaco
    cause dealers are cheap weasels
    Superdave1.0, airmax233 and mquibble like this.
  13. Jan 30, 2023 at 1:13 PM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    This is a failure of the plastic and seal in the cross pipe not a hose. Many other manufacturers have this issue as well. Plastics are tough but not designed to go through heat cycles as well as metal.
    2016Tacoman likes this.
  14. Jan 30, 2023 at 5:42 PM
    2016Tacoman
    J
    Especially when bridged as it is. This is one plastic piece that is rigidly attached on both ends subject to stress movements from heat cycles and vibration. If it were not rigidly attached on both ends it probably would not be an issue.
    Definitely a grade school design. Toyota quality definitely lacking there.
    It is a pipe, not a hose, and legally per the contract they should repair it, period.
    MGMoverland[QUOTED] likes this.
  15. Jan 30, 2023 at 5:43 PM
    #35
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Just dropped mine off this evening.
    Quotes $1,249 parts/labor. :(
  16. Jan 30, 2023 at 7:59 PM
    #36
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Is that your copay or full price?
    Because if not, it sounds like it will be done with the engine in the truck chassis. If the engine is to be pulled, I would think it would be a lot more
  17. Jan 30, 2023 at 8:01 PM
    #37
    The hammer
    Actually a metal crossover pipe might be subject to rust thru penetration and thus leak heavily, especially in the rust belt.
    A good quality plastic would last, but it is evident that the quality is not uniform for TOYOTA on this component.
    I would prefer a cast iron if it’s attached to the engine block like the thermostat housings used to be made, for the life of the vehicle.
    But those days of cast iron are gone in the name of weight reduction for better mpg.
    VTi EG6 likes this.
  18. Jan 31, 2023 at 5:13 AM
    #38
    VTi EG6
    TX
    2017 Taco TRD Sport
    Full price, out of warranty.
    Should be started on it today as I was told they’d keep the vehicle until tomorrow.
    The hammer[QUOTED] likes this.
  19. Jan 31, 2023 at 5:27 AM
    #39
    MGMoverland
    Brad
    Golden, CO
    Most European manufacturers use aluminum for a cross over pipe on V6 or V8 engines. Usually only the seals go bad however in rare instances corrosion will eat away at the aluminum but only if you put a volatile combination of coolants in the system. Same corrosion happens with plastic but only if the coolant becomes acidic (re: mixing certain coolant causes this reaction). I once replaced all the plastic including a heater core when a new beetle owner dumped a bunch of green coolant into their cooling system requiring G12 pink coolant. Very pricey repair.
  20. Jan 31, 2023 at 8:44 AM
    #40
    The hammer
    Well, that's good news! it means some of us can do this at home by just pulling the intake and just paying for the parts.
    I'm still not looking forward to doing any such thing though, but no stealership for me lol!
