Coolant leak from timing belt cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by melinda13, Oct 18, 2023.
  1. Oct 18, 2023 at 10:09 AM
    melinda13
    melinda13 [OP] Member
    ‘06 Tacoma
    Howdy!
    I have an ‘06 Tacoma 2.7L, I4 with 240k miles on it. It has a pretty significant leak coming from my timing belt cover so the sealant/gaskets need replaced.(this is what I’ve been told) My issue is that I’m being quoted 3-4k to fix it because they said the engine needed to be removed to get to the problem. I’ve done a little research and this just doesn’t seem right to me, but I don’t know enough to argue. I’ve put enough money into it the last couple years I hate to give up on her now, but with 240k miles putting 3k into the truck at this point seems a little crazy too. Any information or thoughts would be appreciated!! cheers!
  2. Oct 18, 2023 at 10:12 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is no timing belt cover on a 2nd gen, both engines use timing chains.
    Do you have a 2.7L I4 or the 4.0L V6?
    melinda13[OP] and BillDaCat8 like this.
  3. Oct 18, 2023 at 10:25 AM
    melinda13
    ‘06 Tacoma
    It’s a 2.7L I4
  4. Oct 18, 2023 at 10:33 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    melinda13[QUOTED][OP] likes this.
  5. Oct 18, 2023 at 10:40 AM
    melinda13
    ‘06 Tacoma
    The oil leaking from the timing cover is what I’ve read in my research so I was a bit confused. I dbl checked with the shop to make sure I understood them correctly and they for sure said coolant leak from timing cover. I might have assumed belt.
    Is the thermostat housing difficult to get to?
    just saw the link. I’ll check it out. Thank you
  6. Oct 18, 2023 at 11:43 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Consider seeking a 2nd opinion from a different shop. Don't tell them what the first shop said, beyond perhaps, "I think there might be something with the timing chain cover?"
  7. Oct 18, 2023 at 2:26 PM
    Waasheem
    Waasheem
    2007 xrunner
    Good advice.
  8. Oct 18, 2023 at 2:59 PM
    AZ_TACO
    AZ_TACO Well-Known Member
    2009 PreRunner TRD OR
    Toytec Boss 2.5” Front Toytec Boss 2” Rear SPC UCAs CMC Black Rhino Warlords BFG KO2s aFe Wet EA Filter Rigid D Series Pro
    OP, setting aside what the shop said- do you know if you’re leaking oil, or coolant?
  9. Oct 18, 2023 at 3:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    There is no v4. If you have a 2.7 it's an I4.
    Just to help with the shop lingo.
    IMHO that shop is trying to gouge you.
    As @GilbertOz suggests, get a second opinion from a reputable shop.
  10. Oct 18, 2023 at 3:18 PM
    melinda13
    ‘06 Tacoma
    @Clearwater Bill thank you! I’ll need to google this so I understand it a bit better, but I appreciate the info. Thankfully I’m a carpenter and not a mechanic. :)
  11. Oct 18, 2023 at 3:27 PM
    melinda13
    ‘06 Tacoma
    @AZ_TACO it’s definitely coolant. I had been filling it up about once a week, but it got a lot worse a few weeks ago so I had to stopped driving it.
  12. Oct 18, 2023 at 4:16 PM
    AZ_TACO
    I’m with others, not buying coolant from timing cover. I’m not super familiar with the 2.7s but looking at a diagram I’m thinking by-pass, maybe thermo housing/hose, water pump? Hard to say without seeing it. If you get a second opinion I wouldn’t say anything about timing cover, just note the coolant loss/leak.
    http://www.comajoe.com/misc/05tacopdfs/2tr-fe.pdf
