Coolant leak-misfire cylinder 6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bobbtb1, Apr 2, 2025.
  1. Apr 2, 2025 at 6:40 AM
    Bobbtb1
    Bobbtb1 [OP] New Member
    Bob
    Massachusetts
    2018 Tacoma SR5
    Stock
    Hi. Has anyone else had a similar issue? Misfire code last week, running rough. Pulled coil and found coolant in the plug well and at the top where the coil seal is.
    Dealer performed pressure test-passed (which I’m skeptical of)and cannot determine cause. Certified preowned purchased 4 years ago, still under powertrain warranty. 83,000 miles. Thanks
  2. Apr 2, 2025 at 7:35 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    There is no possible way that coolant can get into a spark plug tube unless there is an external leak to the degree that it gets past the coil. Since it's cylinder #6, I would be inspecting the lines to the heater core in that area...
  3. Apr 2, 2025 at 7:56 AM
    Bobbtb1
    Bob
    Massachusetts
    2018 Tacoma SR5
    Stock
    Thank you Tailhook. I will inspect those lines. That could explain why it passed the pressure test, if the valve to the heater core was closed.
  4. Apr 2, 2025 at 8:14 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I am pretty sure Tacomas do not have a valve and coolant runs to the heater core always.
  5. Apr 2, 2025 at 8:33 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    What color is the coolant? That doesn't look like Toyota coolant if it's not pink or leaves a crust if it's been leaking awhile.
