Coolant leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itaco, Oct 22, 2013.
  1. Oct 22, 2013 at 7:17 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    I have a 2005 double cab 4x4 Tacoma and there seems to be a slow leak. There's coolant on top of the overflow tank right below the cap. What would cause that? evaporation or faulty cap?
  2. Oct 22, 2013 at 7:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Same with my '08.
    Never see the level drop, it's just a bit of weepage where the overflow hose joins.
    If it bothers you, remove the hose, clean it up, and reinstall it with a hose clamp.
    Don't overtighten or it will collapse the plastic.
  3. Oct 22, 2013 at 7:53 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    The dried coolant isn't near the hose. It's right below the overflow tank cap.
  4. Oct 22, 2013 at 7:56 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
  5. Oct 22, 2013 at 8:00 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Maybe it's the overflow tank "throwing up" excess coolant? If that's the case where should your coolant level be when engine is cold? Mine is about halfway between min and max line when cold and when it's hot it's at the max line. But after about a month and a a half the coolant level drops about a cm.
  6. Oct 22, 2013 at 8:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Could be splashing. Pull the cap and clean everything up. That doesn't look bad at all.
  7. Oct 22, 2013 at 8:14 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    I wiped it clean a few times before taking this picture.
  8. Oct 23, 2013 at 4:12 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    Welcome to the Forum. I believe you may have some Hawaiian water to your cooling system and the water is erupting in eco-sympathy with Mauna Loa volcano. Just Kidding.........
    Do you smell any sweet odors that comes from Antifreeze ? Have you ever changed the thermostat or Radiator cap on your Taco ? Do you get any coolant leaks on the floor ? You may want to check this while it is hot and see if water in the overflow tank is bubbling. This should not be happening, and it could be a early warning of a cooling problem. When you answer some the questions, I am sure we will find out what is wrong with your system. Good Luck.
  9. Oct 23, 2013 at 4:28 AM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Haha thanks for the suggestions. I don't smell any antifreeze and as for the rad cap and thermostat I haven't changed any of that yet. I just recently got the truck. Today I drove the truck 80 miles and checked the overflow tank while it was running for any bubbling and it wasn't. Could a bad rad cap be the cause for the dried coolant on my overflow tank?
  10. Oct 23, 2013 at 5:02 AM
    Ga tacoguy
    Rudy
    Augusta Ga.
    Since your Taco is an 05, and it is now 9 model years old, you may want to change the radiator cap first and see if it stops the overflow. A weak spring on the radiator cap would release pressure to the overflow tank and force fluid out. A cap is not that expensive, and you do not need to purchase a Toyota cap to replace it, but some people like to keep their Taco all Toyota. A dealer replacement radiator cap would be double the cost of an aftermarket cap. Good Luck .
  11. Oct 23, 2013 at 5:27 AM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Ok I'll try this and see how it goes
  12. Oct 23, 2013 at 9:51 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Did you taste it to make sure it's not sweet?
  13. Oct 23, 2013 at 9:56 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    I had a quart go missing 2 different times and have yet to figure out where it went...
  14. Oct 23, 2013 at 9:57 AM
    jw1983
    Alberta
    Just in case you were curious, I thought I'd ask.
  15. Oct 23, 2013 at 10:24 AM
    jw1983
    Alberta
    We're all about helping here at TW.
  16. Oct 23, 2013 at 11:05 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    The service writer at the dealer pointed out that mine was overflowing slightly when they were diagnosing it for a blown head gasket. I hope that's not the case with yours but apparently it's a somewhat common issue with 05-08 trucks. They don't leak bad enough to lose hardly any coolant but it pressurizes the cooling system from the # 6 cylinder. Besides a slight occasional gurgling in the dash and a random rough idle for a few seconds (which eventually turned on the CEL for a cylinder 6 misfire) the truck was perfectly fine. I'm pretty sure that's why mine got traded in. Fortunately I caught it before the 30 day/1k mile standard used car warranty ran out and they covered it.
  17. Oct 23, 2013 at 11:18 AM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Wow you pretty much explained what I've been experiencing. I got a misfire on cyl 6 and I hear the gurgling of coolant also. I thought it was because I have air in my system. So what exactly is the problem?head gasket starting to go?
  18. Oct 23, 2013 at 3:57 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
  19. Oct 23, 2013 at 4:11 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    you guys are really freightening me with this headgasket stuff
  20. Oct 23, 2013 at 4:16 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Go get it checked ASAP. IIRC, the '05s (and '04 4Runners) had head gasket failures with #6. My recollection is that there was an early TSB and the head gaskets were redesigned from '06 on. Sounds very much like what you are describing. If so, you'll want to get it fixed before something more expensive gets damaged.
