Coolant Leak?
Discussion in 'Technical Chat' started by CBiscuit14, Aug 29, 2016.
  1. Aug 29, 2016 at 4:22 PM
    CBiscuit14
    CBiscuit14 [OP] Professional Lurker
    South Dakota
    08 DC TRD Sport 4X4
    I have an 08 4.0 4x4 with 78k miles. My coolant level was hanging just above the low line a couple months ago, so I had my mechanic (a buddy) check it out. He couldn't find any leaks and topped off the coolant. It didn't take long for it to drop to about the same level. It has hung there until recently I noticed it was slightly below the line.
    I had an appointment today with my local dealer (ugh) for my leaf spring recall, and had them look at it as well. They topped it off and did an external inspection.... you guessed it.... they didn't find anything. So now they are recommending an internal diagnostic for $350.
    I drove it to work after the appointment. A couple hours later when I left, I noticed a pretty large wet spot under the front of my truck. I checked the coolant and sure enough it was down to just above the low level again. I can't see any coolant residue or any wet spots in my engine bay.
    I changed my oil since my visit to my buddy and it was black like it should be. I checked my oil level the other day and it was NOT milky. I have not noticed any white smoke upon startup or while driving.
    I couldn't find much by searching, mainly just 1st gen coolant problems. Do you guys have any suggestions? I hope to get this figured out without having the stealership do their diagnostics.
  2. Sep 6, 2016 at 4:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you check under the water pump where the weep hole is? You might need an extendable mirror to see it.
    CBiscuit14[OP] and Fenwick1993 like this.
  3. Sep 6, 2016 at 5:33 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Some small leaks will go unnoticed as they dry as fast as they leak. For $350 I would buy my own tool to pressurize system and find the leak myself. The tool wont cost that much
    CBiscuit14[OP] likes this.
  4. Sep 6, 2016 at 5:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Or most parts houses have those in their lender programs.
    I agree with the water pump weep hole as the first check point, as well as the radiator cap, then hose attachment points, then the radiator itself.
    The shops $350 is looking for a blown head gasket. Not uncommon on these from what I read but your mechanic friend can diagnose that for you for much less than $350.
  5. Sep 6, 2016 at 6:04 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ffs save your money
    just taste the water that comes out the tailpipe,
    if sweet, headgasket
    if not, not headgasket
    spit it out of course
  6. Sep 6, 2016 at 6:52 AM
    CBiscuit14
    South Dakota
    08 DC TRD Sport 4X4
    Thanks for the info guys. Since that post I have found out that the spot in the parking lot was not from my truck after all.... which also means the dealer didn't top it off. But regardless there has been a slow leak over time.
    I'll grab a mirror and check the weep hole. And do try the hobo head gasket test.
    Fenwick1993 likes this.
  7. Sep 6, 2016 at 6:56 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Could be the heater core. Usually you will smell it in the cab, but not always. Mine is leaking, but I do not smell it in the cab, and my floor is not wet. It could have picked that perfect spot to leak to where you can't see it or smell it, like mine. Worth investigating it if you can't find any problems in the more obvious areas.
  8. Sep 6, 2016 at 6:58 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I had a 98 Corolla that had a mysterious coolant leak. The bottle kept dropping but no coolant was leaking anywhere. I had the local Toyota dealer pressure test the system and they found nothing. Finally an old mechanic at the Chevy dealer I worked at told me to replace the radiator cap. Turned out that the cap was letting coolant slowly evaporate. Problem solved. A new cap is cheap, so you may give that a shot. Can't hurt.
  9. Sep 6, 2016 at 8:15 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I agree, the gas cap is a good thing to try.
    If the reservoir level drops to the same point every time, then it could be a leak/crack in the reservoir itself. I"ve recently had to replace that item in my '99 Tacoma AND my '01 Corolla. That plastic Toyota uses, seems to age and crack after about 12 years or so.
    Fenwick1993 and CBiscuit14[OP] like this.
  10. Sep 6, 2016 at 8:56 AM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    This is why I don't use my windshield washer fluid in my 96 Tacoma- the reservoir got brittle and now has a massive hole in it. It's only like 13 bucks on rockauto, but I haven't bothered yet.
  11. Sep 6, 2016 at 9:00 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Spitters are quitters!
  12. Apr 3, 2017 at 12:52 PM
    CBiscuit14
    South Dakota
    08 DC TRD Sport 4X4
    Sorry to revive this old thread, but thought I would give an update and provide info for anyone else that may have the same problem in the future.
    I took advice from @NAAC3TACO and replaced the radiator cap (I spent a little extra for the TRD one), and my coolant level has held steady since September.
    InfernoTonka and NAAC3TACO like this.
  13. Apr 3, 2017 at 1:24 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    ^^ be sure to examine the radiator cap rubber seal if you replace one. if it is swollen, or comically
    oversize (the reason it may leak) oil has invaded the cooling system from somewhere
    oil/atf will make rubber seals in cooling system swell and break down
    happened to my 4runner, radiator cap seal was 25% increase in diameter and for
    a minute wondered WTF how did this ever fit in the first place. then found atf cooler seal broke in rad...milkshake
  14. Apr 3, 2017 at 1:51 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    A UV flashlight comes in handy trying to find a coolant leak as well. Not sure if UV works with the new type of coolant though.
