Coolant Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by responsible currency, Dec 26, 2023.
  1. Dec 26, 2023 at 8:54 AM
    responsible currency [OP] Active Member
    Josh
    1997 5 Lug Toyota Tacoma Ext Cab
    I noticed that there was green fluid on the ground recently and wondering if anyone can point me in the right place. Based on the video, could anyone recommend which part would I need to get replaced? Thank you!
    https://imgur.com/a/Hd87haz
  2. Dec 26, 2023 at 9:24 AM
    1997tacomav6
    Denver
    Is your antifreeze green or pink if u look into the radiator, or is it oil based
  3. Dec 26, 2023 at 10:02 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Its coming from the hot return hose into the top of the radiator.....
    its either gone to be that or the top crimp on the hot side of the radiator...
    Most likely where the top radiator hose goes into the engine...loose clamp, or split hose...
    Might be a good time to replace that......that particle hose should be replaced every 3yrs....
    .....most likely one to put you walking....
  4. Dec 26, 2023 at 10:24 AM
    Josh
    green antifreeze
    1997tacomav6[QUOTED] likes this.
  5. Dec 26, 2023 at 10:25 AM
    Josh
    Do you happen to have a link or product number I should buy? I seem to have a hard time finding it
