Coolant leaking under Engine, 99% sure its Waterpump.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Sep 9, 2017.
  1. Sep 9, 2017 at 1:36 PM
    Swivot
    Swivot [OP] Well-Known Member
    I am pretty sure my waterpump is shot. I have a bunch of coolant leaking. My mechanic friend said its fine to drive around for today. But just to make sure that my coolant levels are refilled and to check my temp gauge. Any suggestions out there? I have to drive for my job tonight so it would be nice to have. Do you think its ok to drive with it? Also when I get in there to replace the pump, should i replace any other hoses or belts?
    Thanks guys, its a 2001 Taco V6 3.4L 4by4
  2. Sep 9, 2017 at 1:42 PM
    Swivot
    Ok, I am pretty sure my belts and timing belt were changed recently. Do you think its smart to just replace them while im under there anyways?
  3. Sep 9, 2017 at 3:37 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    They didn't do the water pump with the timing belt?
    Rmodel65 likes this.
  4. Sep 9, 2017 at 3:43 PM
    FromTejasWithLove
    FromTejasWithLove Well-Known Member
    Cale
    Hurricane, Utah
    '99 Taco SR5 4x4 V6; manual everything
    Turtle Top Shell, Rear Single Motorcycle Carrier, Refrigerator
    Yeah at least in our shop, timing belt replacement practically obligates water pump replacement at the same time since either job puts you in the exact same neighborhood as far as labor and it's never fun to pay for the "same job" twice in case your water pump craps on you 1000 miles after your timing belt job.
  5. Sep 9, 2017 at 5:04 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    From what I read water normally have a small leak right before timing belt change is needed. GL
  6. Sep 9, 2017 at 5:44 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    I would have it replaced just to be safe. Wp and timing belt should be replaced together anyways
  7. Sep 9, 2017 at 7:38 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I walked out to my truck and there was a huge puddle of coolant underneath. So I filled up the radiator & overflow to the proper level. Next day same thing. So I got that kit off of E Bay from Aircabinman that included everything and then some! It solved everything from there on out! Like posted above, the water pump seems to be the 1st thing to go out.
    https://www.ebay.com/itm/180729034728
    Dalandser and Crow_of_judgement like this.
  8. Sep 9, 2017 at 8:39 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I had Gates belts from O'reilly's before I put my current belts on. They're good belts too.
  9. Sep 9, 2017 at 9:14 PM
    tony2018
    tony2018 Well-Known Member
    Add on cam seals, crank seals, oil cooler seal and hoses...etc...etc...
  10. Sep 9, 2017 at 11:42 PM
    Swivot
    Thanks for the info, So this truck was bought off CL about 5 months ago. He "said" the timing belt was changed. But if my waterpump is going bad thats an indication that maybe he didn't change the timing belt? I think I am going to buy that kit off ebay and repair it hopefully within a day or two. I just have one concern with that kit from AirCabinMan. Are his parts legit and OEM? I would like to get quality parts so that I am not having my pump and belts fail on me in a short time after I replace them.
  11. Sep 10, 2017 at 2:42 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    x3 Same here. All parts are correct / legit.
    Currygoat and Sicyota04[QUOTED] like this.
  12. Sep 10, 2017 at 4:39 AM
    tony2018
    If they can't provide receipt for parts or the receipt for the work than I would never trust their word, this happened to me before.
  13. Sep 10, 2017 at 4:47 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Some funzanoon might have replaced the timing belt and not the water pump.
  14. Sep 10, 2017 at 6:34 AM
    tony2018
    Seen this happen to my aunts camry. Or worst yet, they just tension the current timing belt but charged her for replacing the timing belt...
    Dalandser[QUOTED] likes this.
  15. Sep 10, 2017 at 7:38 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    When I do take my car or truck to a mechanic, I ask to have the old parts returned to me so I know they aren't still on the car. I don't know what it's like in other states, but in CA this is a right car repair customers have.
    Dalandser likes this.
  16. Sep 10, 2017 at 8:37 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    How many miles were on the water pump?
  17. Sep 10, 2017 at 9:21 AM
    Swivot
    My car is at 135,000. Hmm Yeah who knows what went on when the previous person had this work done. Alright well I don't really want to drop $800 in parts from the Toyota dealership for the belts and water pump. So i guess ill go with the ebay deal. Thanks guys!
  18. Sep 10, 2017 at 9:29 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Are you certain, or just assuming, its the water pump?
    Did you crawl under there and see where the leak was actually coming from?
  19. Sep 10, 2017 at 10:08 AM
    Swivot
    I am pretty certain, My neighbor is good with cars and has had experience with replacing these parts. He looked at it and called it out as 99% sure a bad waterpump just by looking at where the leak is puddling and dripping from. Its dripping from under the engine block not from the radiator.
  20. Sep 10, 2017 at 11:13 AM
    Wulf
    rock raisin
    I had a what appeared to be a leak from that area and it turned out to be a blown head gasket dripping down to there. Just saying.
    I was adding about a gallon of water every time I had to drive it.
