Coolant leaking under Engine, 99% sure its Waterpump.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Sep 9, 2017.
  1. Sep 10, 2017 at 12:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    :eek:
    Are you still driving the truck? If it's just sitting you can take off the belts and remove the timing cover and fan mount to see if it's the water pump before you buy any parts.
    Who's going to be doing the work, your neighbor?
  2. Sep 11, 2017 at 10:02 PM
    Swivot
    Swivot [OP] Well-Known Member
    No I am not driving it. No actually my co worker is going to do it for me. So in case i need to drive it out to his place i want to keep it in working order. If it was a headgasket it shouldn't be leaking coolant right?
  3. Sep 11, 2017 at 11:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Depending on what kind of compression failure you have related to the head, you can have oil seep into the coolant, coolant seep into the cylinders, both, or coolant leaking out of a couple other places.
  4. Sep 12, 2017 at 2:18 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Bad headgaskets will often burn coolant in the cylinder and you'll have a white cloud coming out of your tailpipe even after warm up, and your exhaust will smell like coolant. Sometimes a bad headgasket will also produce a bunch of small bubbles in the coolant overflow tank when the engine is running.
    Leaky water pumps are pretty common, especially if it is the original (they used RTV instead of an actual gasket and they didn't last that long).
