Coolant Level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalesrn, Dec 21, 2011.
  1. Dec 21, 2011 at 6:23 AM
    dalesrn
    dalesrn [OP] Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    Do I fill my coolant level to the maximum line when the engine is cold? It is currently at the minimum line with the engine cold. I have bought the coolant from Toyota, I'm just not sure if I should fill it when the engine is hot or cold, and whether I should fill all the way to the maximum line.
  2. Dec 21, 2011 at 6:25 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    it wont hurt I do that if mine is low in my vehicles
  3. Dec 21, 2011 at 9:48 AM
    myname150
    myname150 Well-Known Member
    ditto, mine was nearing the minimum level. i just filled the reservoir with the pink toyota coolant till i reached the max.
    probably better when cold, i noticed the level reads a little higher after the engine has reached operating temps and i've been driving around.
  4. Dec 21, 2011 at 10:25 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    *generally* the min line is min-cold and the max line is max-hot. But I've seen coolant reservoirs on other vehicles that specify a min and max for both hot and cold.
  5. Dec 22, 2011 at 7:09 AM
    dalesrn
    Dale
    Southeast Louisiana
    With all this said, should I just add fluid to the reservoir to a level between min and max when it is cold?
  6. Dec 22, 2011 at 9:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That will be sufficient.
    The bigger question is where is the coolant going? Water pump leak, burning coolant via head or egr, radiator leak? A tiny amount will evaporate over time. How often do you have to top it off?
  7. Dec 22, 2011 at 2:33 PM
    dalesrn
    Dale
    Southeast Louisiana
    Almost definite by evaporation. This is the first time I have had to add fluid and it is a 2008 with 40,000 miles. I think I am OK. I am the original owner.
  8. Dec 22, 2011 at 3:09 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I just picked up some Toyota Long life yesterday to refill the overflow. I filled it up and let the truck run to temp and it was almost at the full line so I left it. I also had to fill the power steering reservoir a little too. Luckily I had a new bottle of ATF fluid in the garage so I used a turkey baster with an extension on the nozzle to take out what I could from the reservoir and filled it back up to the cold max level.
  9. Dec 22, 2011 at 6:06 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I fill mine to just below the max line when fully warmed up. It will go higher than that when running up hills and such on a hot day. The gauge doesn't move, but that does not mean it isn't heating up a bit. If you fill to max when cold, it will puke out on the ground if you get it hot enough.
  10. Dec 22, 2011 at 6:22 PM
    dalesrn
    Dale
    Southeast Louisiana
    Did you fill it to the full line when it was cold? If so, have you had problems with it overflowing when the truck is warmed up?
  11. Dec 22, 2011 at 7:03 PM
    08TacoTrD
    08 TRD Offroad
    First I checked the fluid level in the radiator when it was cold to see if it was full and then I added some coolant to the overflow (closer to high than low) and ran my truck until it was up to temp and checked the level in the reservoir. Since it was basically at full I called it good. Remember it's an overflow reservoir that's there for the coolant when the system gets hot. I figure as long as it's within the upper and lower levels it's good.
  12. Nov 25, 2012 at 6:33 PM
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    Quick question:
    Why did you take all of the fluid out of the reservoir? Could you not just add some to it?
  13. Nov 26, 2012 at 2:32 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Fluid change, probably. It does get dirty.
