Coolant levels are frustrating!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rawdoggy, May 30, 2020.
  1. Jun 1, 2020 at 7:09 AM
    #81
    Rawdoggy
    Rawdoggy [OP] Well-Known Member
    The radiator is full. But the resi still depletes down the below low. Every time.
  2. Jun 1, 2020 at 9:37 AM
    #82
    Rawdoggy
    All right up date everybody. Got a call, no damage to radiator, but seems to be leaking. So they are replacing the radiator.
    appreciate everyone’s help in this issue. Once I go in I’ll get more info/post tech notes. Very weird. Thank god for warranty
  3. Jun 1, 2020 at 9:38 AM
    #83
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Weird. Cracked sides?
  4. Jun 1, 2020 at 9:39 AM
    #84
    Rawdoggy
    She said the tech didn’t see any physical damage, and it was just leaking. I’ll get more info when I go in, it was just one of the girls who called to let me know to scoop up the rental.
  5. Jun 1, 2020 at 9:54 AM
    #85
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Leaking radiator, but no coolant...
    Milkshake time?
    jmauvais, doublethebass and Skydvrr like this.
  6. Jun 1, 2020 at 9:54 AM
    #86
    Rawdoggy
    don’t know what milkshake time means!
    I wonder, could this of fucked Up my engine? Should I be asking for more than just a radiator?
  7. Jun 1, 2020 at 9:57 AM
    #87
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Would this be covered under 60k drivetrain warranty? i think i have same issue.
  8. Jun 1, 2020 at 9:58 AM
    #88
    Rawdoggy
    From what I’ve read, no. Radiator is not a direct engine component, it’s classified as an accessory or something weird..
  9. Jun 1, 2020 at 10:02 AM
    #89
    Hank Heel
    WA
    Well that sucks. I'm an idiot for not taking mine in when i had the warranty. Let us know what tech/notes say.
    Thanks
    Edit:
    Here is my thread btw, the consensus in responses was that its normal.
    https://www.tacomaworld.com/threads/coolant-reservoir-low.618283/
  10. Jun 1, 2020 at 10:05 AM
    #90
    Rawdoggy
    For sure, after reading more.. I wonder if it’s been going on for awhile and the techs didn’t catch it at last service. Which could’ve mucked up engine gaskets to transmission?
    When I go back and they have “ fixed the problem” if I don’t see anything about checking tranny etc, should I ask for them to look since it could possibly cause issues there? I’ve literally got less than 2 months of bumper to bumper lol, this has gotta be fixed before.
    Hank Heel[QUOTED] likes this.
  11. Jun 1, 2020 at 10:09 AM
    #91
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Think this only happens to people with 3rd gens named Gregg
    BillsSR5 likes this.
  12. Jun 1, 2020 at 10:09 AM
    #92
    Rawdoggy
    Haha
  13. Jun 1, 2020 at 10:10 AM
    #93
    Hank Heel
    WA
    Generally techs dont care, they do the bare minimum to fulfill toyota care warranty and send you on your way, at least from my experience.
    Definitely a good catch before the warranty is up.
    Rawdoggy[QUOTED][OP] likes this.
  14. Jun 1, 2020 at 10:22 AM
    #94
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Milkshake is the mix of oil and coolant. A leak the size youre seeing should present itself either externally or internally.
    External leaks should show on a line pressurization test as air and coolant will escape. External leaks should have a visible residue, pink and chalky. There would be a sweetish smell, like syrup while running hot.
    Internal leaks are the real concern. Not trying to scare you here. Leaking reservoirs that disappear to no where are draining to somewhere. Pulling the engine oil cap and seeing a yellowish (snot like) or white foamy residue can be sign of coolant mixing. Next would be a sweetish smell out the exhaust or excessive white smoke as the coolant is burned off begins to bypass seals and exits the exhaust. Eventually you'll get a CEL as the coolant will destroy the converter and foul sensors. By then youre usually F'ed.
    I would request pictures or proof the external leak if it exists. If they dont have one, be diligent on watching the reservoir level after they return the truck to you.
    Oil lab analysis would be a good idea to verify there's no residual trace coolant.
    MountainManGuy likes this.
  15. Jun 1, 2020 at 10:25 AM
    #95
    Rawdoggy
    should I call back and request them to check the tranny, oil, head gaskets?
  16. Jun 1, 2020 at 10:25 AM
    #96
    elduder
    Van WA
    As long as the leak is external and they can prove that, you should be fine. Assuming the truck never overheated. Reservoirs are the back up the radiators, running them low is "ok", once theyre empty its just a guess to how full the radiator is.
  17. Jun 1, 2020 at 10:28 AM
    #97
    Rawdoggy
    Should they have checked gaskets, tranny, oil? Or do I have to specifically request this, don’t want to end up getting screwed. Lol
  18. Jun 1, 2020 at 10:28 AM
    #98
    elduder
    Van WA
    Trans should be fine. No way to check for head gaskets other than disassembly or a compression test, but you havent had any issues with it running rough or misfire.
    If the leak is external, then just get an oil lab done after the next oil change.
  19. Jun 1, 2020 at 10:29 AM
    #99
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's transmission fluid. Where the trans cooler goes into the radiator
    Sharpish likes this.
  20. Jun 1, 2020 at 10:30 AM
    #100
    Rawdoggy
    my MPG went to shit, could that be misfires? I went to low 15’s I don’t know. Something just isn’t right.
