coolant lines stiff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Martintaco13, May 17, 2023.
  1. May 17, 2023 at 8:12 PM
    Martintaco13
    Martintaco13 [OP] Member
    i have 13 toyota tacoma i have a concern after a long drive when i touch the upper and lower coolant lines there both stiff and hot is this normal ??it does have a new radiator and thermostat no signs of overheating last drive i did was 8 hours long
  2. May 17, 2023 at 8:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Open the radiator cap just to make sure.
    I'm joking.. lol. Yes it's entirely normal for them to be stiff after a long drive. Think of it this way. Hot water expands, cold water contracts. (Basic explanation of it)
    Dm93 likes this.
  3. May 17, 2023 at 8:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds normal to me, if everything is operating properly coolant temp is gona be around 180-200F and the radiator cap maintains pressure on the system up to around 13 psi.
    If you aren't losing any coolant and not overheating everything is fine.
  4. May 17, 2023 at 8:17 PM
    Martintaco13
    ok thanks i was just concerned about head gasket
  5. May 17, 2023 at 8:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Nah, if you had a headgasket leak you would either be losing coolant or pushing it out of the overflow bottle.
    Pretty uncommon for 07 and up 4.0's to have a headgasket fail unless they have been overheated.
  6. May 17, 2023 at 8:22 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    On a hot engine, do not open the radiator cap when the upper hose is stiff. That means the system is pressurized and opening the cap can cause burns from the hot water gushing out.
    I don’t even open the radiator cap on an engine that has cooled down without checking the top hose.
    Dm93 likes this.
  7. May 17, 2023 at 9:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    I guessing the radiator and thermostat you didn’t do yourself?
    I’ll often find the radiator upper and lower hoses need replacing because they’re hard as a rock instead of being pliable like they should be. Sometimes they’re so bad they crack as soon as you try to move them. Sometimes they’re so stiff they won’t come off the radiator. I’m sure if they needed it, they got replaced with the radiator.
  8. May 23, 2023 at 5:56 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    What is the change interval on radiator hoses? Does 2nd gen only have two hoses?
