Coolant loss on a 2.7 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tractng, Nov 11, 2017.
  1. Jan 2, 2018 at 9:29 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Try the radiator cap first. I had a 1998 corolla that had the same problem. The coolant was slowly evaporating through the old cap. Now I change caps about every 5 years. This may not be the problem, but if the cap is old, it should be replaced anyway. Good luck.
    Steves104x4 and winkel like this.
  2. Jan 2, 2018 at 9:34 AM
    tractng
    tractng [OP] Well-Known Member
    Good idea on the cap.
  3. Jan 2, 2018 at 9:46 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    coolant should be between low and full mark cuz it fluctuates with temperature
  4. Jan 2, 2018 at 10:38 AM
    tractng
    Question regarding the block test (leak test). Can I use the reservoir tank instead of the radiator cap location? I tested both but at the radiator cap location, I didn't remove enough coolant so the tester was above the tip of the cap.
  5. Jan 2, 2018 at 11:10 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not my engine. I was just helping a fellow TW Member with information.
    You should be able to find all the information you need here:
    http://www.customtacos.com/tech.old/files/05FSM/repair.html
  6. Jan 3, 2018 at 10:28 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    need to use radiator cap location for the right readings
  7. Jan 3, 2018 at 10:33 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  8. Jan 3, 2018 at 10:36 AM
    tractng
    I bought a siphon last night and was able to use the radiator cap. Good result so far.
    dillonk1602[QUOTED] likes this.
  9. Feb 12, 2020 at 1:27 PM
    JCos327
    JCos327 Active Member
    Jose
    New Jersey
    08 2.7L SR5 5 speed 4x4
    LCE headers, AFE CAI, Magnaflow Exhaust, 5100 Billestien front and back w/ add a leaf, Homertaco Grill, 275/70/R18 Toyo M/T, 18” XD Thump Wheels, AMP retractable steps, 10” Alpine Type S Sub and Amp, infinity door speakers
    Did Toyota replace this for $70, or was the part $70 and you did the work?
  10. Feb 12, 2020 at 4:10 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    New radiator cap was going to be my first suggestion too. Also, it's a different application but I just replaced the timing belt and water pump on my wife's Sienna. The weep hole in the water pump had a lot of dried pink coolant crusted under the weep hole.
    Just another thought.
    NAAC3TACO and Steves104x4 like this.
