Coolant loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by shankyjones, Mar 7, 2023.
  1. Mar 7, 2023 at 4:18 PM
    shankyjones
    shankyjones [OP] Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Hey y'all, I am having an issue with coolant. My overflow reservoir is down almost 3/4 qt in 2 days. I have searched for leaks but do not see any. I have an 03 Tacoma Prerunner 6cyl 2wd 3.4L auto.
    any ideas as to why? My water pump and timing belt were done about 2 1/2 year ago and there are no visible leaks in that area.
  2. Mar 7, 2023 at 4:44 PM
    shankyjones
    Richard
    Marina CA
    Also, no puddles and no coolant on the skid plates. Just replaced the screw-type radiator hose clamps with spring clamps over the weekend. No leaks at the hoses, both upper and lower. Hoses are fairly new (2 1/2) years were replaced during the water pump/timing belt job.
  3. Mar 7, 2023 at 4:51 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    What does the dipstick look like?
  4. Mar 7, 2023 at 4:52 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Any missing when you start it up? I'd probably do a exhaust gas test in the coolant just to rule out a head gasket leak and keep an eye on the engine oil. I'd also carefully check under the heater and make sure the core isn't leaking and ending up under the mat or carpet. Does it smell ''different'' inside the cab?
  5. Mar 7, 2023 at 4:54 PM
    shankyjones
    Richard
    Marina CA
    Matt, the oil is clean but looks a bit 'red' on my yellow microfibre towel. Is that a bad sign??
    Fxntime, I will start it up and look for any leaks.
    Matt Sierra likes this.
  6. Mar 7, 2023 at 4:55 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What does your exhaust look like?
  7. Mar 7, 2023 at 4:56 PM
    shankyjones
    Richard
    Marina CA
    rnish, tail pipe is dry...no oil nor coolant
  8. Mar 7, 2023 at 4:58 PM
    Matt Sierra
    NorCal
    2020 TRD Pro MT
    With the amount of coolant you’re losing, if it were going into the oil I’d expect it to be cloudy if you check it right after the truck has been running. I think we’re all concerned about head gasket issues though.
    colton1er likes this.
  9. Mar 7, 2023 at 5:00 PM
    shankyjones
    Richard
    Marina CA
    Oh geez...I will check out the oil and look for coolant leaks after I start it up.
  10. Mar 7, 2023 at 5:11 PM
    shankyjones
    Richard
    Marina CA
    The coolant loss was about 1/2 quart. Oil looks good, tail pipe is clean.
  11. Mar 7, 2023 at 5:15 PM
    shankyjones
    Richard
    Marina CA
    No smells within the cab. Heater doesn't seem to be leaking
  12. Mar 7, 2023 at 5:26 PM
    shankyjones
    Richard
    Marina CA
    Engine runs just fine...no misfires nor codes. No smoke (white or black) coming out of the exhaust pipe. No milkey residue on the inside of the oil fill cap.
  13. Mar 7, 2023 at 5:34 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I'll take intake gaskets for 200 Alex....
  14. Mar 8, 2023 at 10:19 AM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    I had a 3.4 that was going through coolant like that once. It never was getting into my oil. It was burning and escaping out my exhaust. One of the heads ended up having a crack in it. Get yourself a tester.
  15. Mar 12, 2023 at 6:51 PM
    shankyjones
    Richard
    Marina CA
    I had ordered a blue dye kit but just canceled it. I think I found my problem! Apparently the lower radiator hose clamp on the engine side was loose so I tightened it up. Haven't loss hardly any since. I will be changing the clamps to spring type just as I did the upper hose.
    Student of Mountains likes this.
