coolant lost after head gasket job..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808manokman, Nov 15, 2024.
  1. Nov 15, 2024 at 11:46 AM
    808manokman
    808manokman [OP] Active Member
    Vic
    2007 Tacoma 2TR-FE 2.7
    100% stock
    My 2007 2.7 Tacoma I noticed the other day the coolant was kinda low no visible leaks that I see. So I filled to up and ran the truck like normal. The temperature gauge stayed normal no climbing or overheating I was watching that all day. I recently did the head gasket due to a burn valve in the exhaust and a bent intake valve. Changed everything related to the cooling system. So this morning I checked the coolant level again I was a little low again! Also the coolant overflow bottle was filled past the full line! Anybody else had this problem?
  2. Nov 16, 2024 at 10:58 AM
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    Possible air pocket from refilling cooling system after repairs?
  3. Nov 19, 2024 at 2:40 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Gotta be air in system. Raise the front end while burping system.
  4. Nov 20, 2024 at 9:11 AM
    808manokman
    Vic
    100% stock
    After checking the cooling system found out that the radiator cap was the one that was leaking! Cap was not even a month old!
    deanosaurus and Leomania like this.
