Coolant lost at times?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flatsaxblues, Feb 1, 2016.
  1. Feb 1, 2016 at 3:33 PM
    flatsaxblues
    flatsaxblues [OP] Member
    Gary
    Oklahoma
    05 PreRunner SR5
    Firestone Ride Rite Air-bag suspension
    05 PreRunner 2WD V6 Automatic. I have noticed the coolant level dropping. But it doesn't seem to be doing it all time. Have not found any signs of leaks around engine compartment or on the ground. The first time I notìce this, I was cĺeaning out the glovebox and found that it was damp. But after clearing out glovebox, and placing a papertowel inside, haven't seen any signs of the leak. My fìrst thought is the heater coil might be the issue.
    Any thoughts?
  2. Feb 3, 2016 at 2:51 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    Have a mechanic do a pressure test to see if your water pump is bad ....
    It's a starting place...
  3. Feb 3, 2016 at 4:26 PM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    My 05 did this too. Pressure tested. Never could find out where it went.
  4. Feb 4, 2016 at 10:15 AM
    flatsaxblues
    Gary
    Oklahoma
    05 PreRunner SR5
    Thanks Yoda & Jokker! I will definitely start with the pressure test.
  5. Feb 4, 2016 at 10:17 AM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    I replaced my water pump, no leaks, but it does need to be topped off once in a while
  6. Feb 4, 2016 at 10:28 AM
    flatsaxblues
    Gary
    Oklahoma
    05 PreRunner SR5
    Thanks "thewarriordinghy"! I haven't seen signs of a leak in the water pump area. But, I will not rule it out.
  7. Feb 4, 2016 at 10:28 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Different engine, but I usually have to top off about every 9 months or so. Coolant will slowly evaporate through the vent in the overflow. That said, when my water pump went bad at ~20,000 miles, it only had a slow trickle from the weep hole. Never reached the ground but it left a pink trail of crust down the front of the engine block.
  8. Feb 4, 2016 at 10:35 AM
    flatsaxblues
    Gary
    Oklahoma
    05 PreRunner SR5
    I will take another look to see any signs. Thanks ecoterragaia
    thewarriordinghy likes this.
  9. Feb 4, 2016 at 10:42 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    No problem
  10. Feb 4, 2016 at 10:46 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Pressure test and do that thoroughly. You have 05 Truck and those are "known" to have head gasket problem.once you replace it it will work but factory HG had some issue.
  11. Feb 4, 2016 at 11:16 AM
    flatsaxblues
    Gary
    Oklahoma
    05 PreRunner SR5
    BlueT, would I be able to see any signs of a bad head gasket? Like foaming on the oil dipstix. I'm not losing coolant continuously. Thanks for shedding some more light on this problem!
  12. Feb 4, 2016 at 11:30 AM
    BlueT
    NorthEast
    Do search on the 2gen forum for headgasket issue, there are a lot of different things that may show up, most is now written up in various threads.
    If you catch headgasket right at the beginning, all you need is new headgasket, than will need new or machined heads, and lastly if you completely ignore a new engine.
    So you need to find a leak.
    whopper likes this.
  13. Feb 4, 2016 at 11:55 AM
    flatsaxblues
    Gary
    Oklahoma
    05 PreRunner SR5
    Great BlueT. Thanks for pointing me in that direction.
