coolant overflow filling up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blacoma1, Mar 18, 2014.
  1. Mar 19, 2014 at 7:32 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Can't u siphon or leak some of that out?
  2. Mar 19, 2014 at 8:16 PM
    169.254.255.201
    169.254.255.201 Well-Known Member
    Interwebs
    I don't know much about this stuff, but I think the issue is the coolant isn't going into the right places so the reservoir is filling up right away. (Reservoir should only fill up when the engine is very hot/pressurized) If he was to keep on removing/siphon coolant out because it kept on overflowing he would eventually be left without any coolant.
  3. Mar 20, 2014 at 12:07 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    did the dealer test your radiator cap? if it doesnt hold pressure that could be your problem. go for the easy stuff first
  4. Mar 20, 2014 at 12:11 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This, it's really easy to do a pressure test on a radiator cap (and a radiator for that matter).
  5. Mar 20, 2014 at 2:50 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Too much coolant in the system!? If a dealer ever told me that I don't think I would ever return to them. Who ever made that statement has no business working on a vehicle.
  6. Mar 20, 2014 at 8:00 AM
    blacoma1
    blacoma1 [OP] Active Member
    05 double cab sport 4X4 trd s/c
    icon stage 4, flow master, all pro front bumper with stealth winch, fab fours rear bumper, airraid intake, trd, s/c, unichip, paint matched bushwhacker fender flares, throttle body spacer,
    new cap was installed and tested, coolant was flushed and filled at the dealership, under normal driving levels stay the same, when i stomp on it for a bit, the reservoir fills up
  7. Mar 20, 2014 at 8:04 AM
    blacoma1
    yeah i wish i didn't have to drive home, but i have to get back to work, probably gonna buy a used motor hopefully with low miles, and have it built, with aftermarket gaskets and studs,
  8. Mar 20, 2014 at 8:24 AM
    blacoma1
    they ran every test they could, tested the block when hot and cold, leak down test, put it on the smog machine, and everything checks out normal, i gonna miss that boost for a while at least
  9. Mar 20, 2014 at 3:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    SC induced leakage by the head gasket. It will get worse.
  10. Mar 20, 2014 at 3:46 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Where's Torq when you need him? He would probably know better than just about anyone.
  11. Mar 20, 2014 at 3:50 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Pull your spark plugs and check for coolant residue. The only leak test they do at the dealership is pressure test and smog. A dye test will be more accurate.
  12. Mar 22, 2014 at 5:54 PM
    blacoma1
    drove 10 hours home, now i need to decide on whether to have my head gasket replaced, possibly with aftermarket gaskets and head studs, or buy a used motor, possibly just leave it stock, my oil looks like brand new, no coolant under the oil fill cap, coolant is clean also...what to do, 130k on this motor,
  13. Mar 25, 2014 at 6:15 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Just replace the head gaskets. No need to replace the engine.
  14. Mar 25, 2014 at 8:31 AM
    blacoma1
    thanks for the input, its in the shop, its gonna be a long week without her
  15. Mar 25, 2014 at 10:20 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To bad I hadn't seen this sooner.
    http://www.dezod.com/cat_engine4.cfm
    Head studs and head gaskets in there. The OEM head bolts are torque to yield. As well, they are over stretched during install, by design. They just don't have the tensile strength of the higher quality ARP head studs. Over time, they stretch. More so will the addition of boost.
    The head gaskets, are very weak design, when introduced to boost. Their middle layer is extremely thin, inadequate for higher boost levels. Above 10 psi. This is one reason why the stock setup is set to 6 psi, and the tune is "usually" very safe.
    Jimmyh has said it well. Boost related blow by, from the cylinders. Head gaskets and head studs, will do perfectly. Just needs to be installed by a competent person.
  16. Mar 25, 2014 at 1:07 PM
    #36
    blacoma1
    wow thank you, super helpful, i am going with cometic HG's and arp head studs, the mechanic has a small shop, he raced cars for 20 some years, he has replaced plenty gaskets, i just hope he gets the correct torque specs for the arp studs and the aftermarket gasket, would they differ from the stock setup?
  17. Mar 25, 2014 at 1:19 PM
    #37
    blacoma1
    i also have a unichip installed, and the map seemed way more aggressive then the stock ecu with reflash, but i also blew the head gasket after a week of using the unichip, it seemed to run better with the unichip and did feel like it had a lot more power, should i go back to the ref lashed stock edu? any thoughts on that anyone ?
  18. Mar 25, 2014 at 1:48 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    80 ft/lbs
  19. Mar 25, 2014 at 3:16 PM
    #39
    savedone
    Gerald
    Texas
    This is interesting. However I do question this. Do you have any proven stats showing that the head bolts are torqued to yield point. I ask this because the 4.0 engine is made of aluminum, heads and block. To be able to stretch a steel stud to yield in an aluminum block without stripping the block with aluminum heads threads is doubtful unless the size (dia.) of the stud is too small.
    Also even when the block is steel and the heads are aluminum you still cannot torque to the same as steel heads since you crush the aluminum heads.
    I would be interested in seeing any data you have on this. Thank you.
  20. Mar 25, 2014 at 5:50 PM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nope. I did over state that. As going to 90 - 100 ft pounds would likely strip out the threads in the block and or deform the heads, and if it did hold, very likely deform the cylinders as well. Egg shape them. Be I that they are only an 11 mm thread diameter, it would most likely pull the threads out first.
    They honestly might not be, but I can bet good money that the OEM bolts do not have near the tensile strength of the ARP 2000 series studs, regardless of if they are at a yielded point. All I know about the factory bolts is that they are torqued to 20 foot pounds, then turned 180°, with a thin coat of oil on the threads. Not sure how much that addition of 180° adds to the additional 20, but I it is a lot, and you don't re-use them, per factory spec. A stretch gauge would be able to tell you how much they have stretched in that torque process. I have never checked them, nor care to.
    A good basis to go by is listed on ARP's website, about OEM torque to yield bolts.
