Coolant Pipe
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PTSDTherapy, Mar 14, 2023.
  1. Mar 14, 2023 at 2:13 PM
    PTSDTherapy
    PTSDTherapy [OP] Well-Known Member
    22 SR5 DCSB
    2022 SR5 bought October 11 2022. 4185 miles. Wife and I just came home from early dinner. Got out smelled coolant. Popped the hood and bingo. Mines is actually dripping from the crossover pipe down onto the top of the transmission and splashing on the cats. And I’m supposed to go to Wyoming next month for 3 months. Absolute bullshit.
  2. Mar 14, 2023 at 2:28 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    get it to the dealer ASAP and tell them your plans.
    HisDad, SR-71A and TnShooter like this.
  3. Mar 14, 2023 at 2:59 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Sucks. I think it is only a matter of time before the aftermarket comes up with a metal replacement. I don't expect Toyota to do that. Doesn't give you the warm and fuzzies about plastic parts.
  4. Mar 14, 2023 at 3:05 PM
    PTSDTherapy
    22 SR5 DCSB
    Doesn’t give the warm and fuzzies about anything on this truck right now. GM vehicles you expect this shit from but damn….
    LeakyAC and kahanabob like this.
  5. Mar 14, 2023 at 3:12 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    OP..can you ask if they just replace with the same part or is it a new and improved?
    if is the same won't be long until someone posts that they had it replaced and the replacement is now leaking.
    2022 and they have not addressed it yet!!!
  6. Mar 14, 2023 at 3:45 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Thought that coolant pipe leak was long past. First time I've heard on a newer tacoma. Makes wonder now the upgraded pipe part number now leak's to.
    shakerhood likes this.
  7. Mar 14, 2023 at 4:12 PM
    PTSDTherapy
    22 SR5 DCSB
    So here’s a thought. They come quick and fast when I’m pissed off at shit…like I am now.
    I can fab shit, fix shit, you name it. Thanks to my grandfather. I don’t know jack about chemistry through.
    I know our blocks are aluminum as well as other parts that contact the coolant. Anyone by chance know what type of aluminum our blocks are made of?
    My tig ability is lacking on aluminum but I can crank on stainless. I’m just thinking there has to be a better way to make these f’n things. I can fab headers with stainless but I think there are issues with stainless and coolant if I remember. Wouldn’t be any different than a custom header bend and two gasket manifolds. Really need to get my game up to speed on aluminum.
    Topanga Taco and mquibble like this.
  8. Mar 14, 2023 at 4:13 PM
    PTSDTherapy
    22 SR5 DCSB
    I keep hearing about an updated crossover pipe. Anyone have a part number for the supposed “old” part number so I can check the changes compared to the current part number?
  9. Mar 14, 2023 at 5:58 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    They still can't stop the timing cover from leaking after all these years, Why the hell do you think there going to care about fixing the crossover pipe.:facepalm:
    bulalo and kahanabob like this.
  10. Mar 14, 2023 at 6:00 PM
    Bishop84
    Bishop84 Well-Known Member
    They are a simple fix on the later models like the 2022, you simply re-seat it. It's an assembly problem. They should be able to fix it in a day. It's slow season.
    No vehicle is perfect.
  11. Mar 14, 2023 at 9:01 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Search this hometown’s knowledge…Hard to beat for TIG.
    https://m.youtube.com/watch?v=61xkueYn5wk
  12. Mar 14, 2023 at 9:02 PM
    Topanga Taco
    Rick
    May the force be with you :welder:
  13. Mar 15, 2023 at 5:14 AM
    zoo truck
    None
    I thought they did fix the crossover pipe leak years ago. Haven't heard of any new issues till now. As far as the timing cover leak...keep crossing your fingers hoping its the next guys problem.
  14. Mar 15, 2023 at 5:23 AM
    PTSDTherapy
    22 SR5 DCSB
    Topanga Taco[QUOTED] likes this.
  15. Mar 15, 2023 at 5:39 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    With it being a new vehicle I would assume either a gasket was not properly aligned or bolts not properly torqued. Probably does not needs a new pipe.
    Canadian Caber likes this.
  16. Mar 15, 2023 at 6:57 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  17. Mar 15, 2023 at 8:44 AM
    Señor
    Señor Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    auskip07 likes this.
  18. Mar 15, 2023 at 9:08 PM
    jerkwithkeyboard
    Nope i have a very small drip at 60K i hope that's all i get...
  19. Mar 16, 2023 at 4:18 AM
    zoo truck
    None
    All my experience with leaks, they don't get better, just the opposite. Time to get out that flex seal stuff.
  20. Mar 16, 2023 at 6:07 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    So you have a defect, it is really that big of a deal? I'm pretty sure the dealer will replace it and you will never have another issue. While that part seems to fail quicker than other parts, I don't think there is really need for a knee jerk reaction to go out and build a new one. Toyota sells hundreds of thousands of Tacomas every year, your issue is really a very small percentage and as others have said it is very rare occurrence. Have your dealer fix it and enjoy your trip.
