Coolant Problem on 2.7L Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt3D, Aug 12, 2020.
  1. Aug 18, 2020 at 4:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The latest statement leads me more towards headgasket.
    You can pull the spark plugs and inspect them. Sometimes there will be obvious signs.
    Be thorough. You'll find the problem.
    matt3D[OP], D2. and Jimmyh like this.
  2. Aug 18, 2020 at 7:08 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'm confused. Why did you replace the thermostat? What was it doing before that?
  3. Sep 4, 2020 at 5:37 PM
    matt3D
    matt3D [OP] Member
    Matthew
    California
    05 Tacoma SR5 AC
    Hi Andrew, sorry for the confusion. The first time it overheated the thermostat was not replaced. After it overheated as I described we replaced the thermostat. But as it turns out it wasn’t the thermostat because my truck still overheats after driving for at least an hour and then coming to a stop and idling for a minute or less. I just dropped the truck off at auto repair shop. I’ll let you guys know what they say.
  4. Sep 4, 2020 at 7:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cool. Good to know that you're still around to update. Keep us posted!
    matt3D[OP] likes this.
  5. Oct 6, 2020 at 3:06 PM
    matt3D
    matt3D [OP] Member
    Matthew
    California
    05 Tacoma SR5 AC
    Hi guys! So as it turns out the head gasket is worn out. We had a reputable shop look at it and for them to replace the head gasket, timing chain, belts, hoses, main seals, etc. would cost $4500 to $5500. My dad went to another shop that said they would charge around $1500 to replace the head gasket/timing chain and also check the block for cracks using the magnuflux method. They also stated that they would resurface the cylinder heads if needed. We have been looking for a good used engine but it seems that when they come up they sell fast at least for the price I would like to pay which is around $2000 or so. My dad found one with 100,000 miles or so for only $1600 but it sold quickly. Do you guys think I should just have the current engine fixed up or just find a good used motor? I realize that my engine has 290,000 miles on it and can have more issues but if the shop determines everything else is in good shape then I suppose it would be best to just fix up the engine already in the truck.
    Thanks,
    Matthew
  6. Oct 6, 2020 at 4:02 PM
    Muddinfun
    Muddinfun Well-Known Member
    I wouldn’t put big money into any engine with 290K miles on it.
  7. Oct 6, 2020 at 5:02 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    What method did they use determine, for sure, it was a head gasket?
