Coolant question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JayDawg, May 9, 2012.
  1. May 9, 2012 at 9:53 PM
    JayDawg
    JayDawg [OP] Christian Pastor. Need prayer,have questions? Ask
    Jay
    Sterling, Co. via San Diego, Ca.
    Tacoma 4x4 Access Cab TRD Off Road Package
    4-PIAA 80 Racing Series Off Road Lights, Randy Ellis Design Light Bar, Bilstein 5100 Shocks, Rear Leaf TSB, Mickey Thompson Classic Lock wheels, fog light mod, more to come...
    When I was power washing my engine the other day I noticed that my coolant reservoir was empty. Tonight I pulled off the radiator cap to check the coolant level. I can see coolant at the top of the radiator but would like to top it off. On these Tacoma's do we have to use the Toyota coolant or can we use other stuff? If we can use other stuff, what is one I can mix with the factory Toyota coolant?
    Thanks!
    Jay
  2. May 9, 2012 at 9:56 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Drain and flush. Check for leaks. I think its 50/50
  3. May 9, 2012 at 10:05 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I think the change interval is at 100k miles. Just go buy a gallon of distilled water and fill the resevoir to the low line. Unless you have choclate milk in your engine oil or a coolant puddle under your truck, I doubt there is a problem.
  4. May 9, 2012 at 10:15 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    good advice. if it's just the reservoir that's low, just add distilled water. keep an eye on it and find where the leak is. to answer your question, yes, always try to use toyota coolant.
  5. May 9, 2012 at 11:09 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    5 year old coolent. I would change it.
  6. May 9, 2012 at 11:55 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    If you're not going to do a proper flush, at least drain the entire radiator, fill that, and the resi with 50/50 mix of long life red Toyota coolant.
  7. Jun 13, 2012 at 7:09 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Sorry for reviving an old thread, but my coolant resi is also below the low line and has been like that for a few months now. Truck doesn't get hot at all but I'd still like to top it off. I have never seen any leaks and its an 09 with 40k on it. Radiator is full. Is it OK to put some distilled water just to top it off or should really buy a whole gallon from Toyota. Thanks
  8. Jun 13, 2012 at 8:01 PM
    Fury
    Fury Well-Known Member
    Hi all.
    Buy the gallon of 50/50 mix from Toyota.
    Don't get in the habit of adding water. Even if you live somewhere where you don't need the freeze protection, you still want to keep the ratio of coolant to water for various reasons.
    Here in Canada the ratio is 55 % coolant to 45 % water for the freeze protection.
    Cheers..
  9. Jun 13, 2012 at 9:13 PM
    badger
    badger Well-Known Member
    07 SR5
    These systems lose a tiny bit of coolant to evaporation over time, like maybe a pint in 5 years. Replacing that with water is no big deal. Bear in mind that the stuff that is evaporating IS water. Mine is 5 years old now too but I only have 75K on the truck. I'll be changing mine completely this fall. IMO 5 years is long enough for any coolant.
