coolant question
Discussion in '4 Cylinder' started by 08pretaco, Nov 30, 2009.
  1. Nov 30, 2009 at 5:48 PM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    after offroading i went from almost full to just barely above the low line. just curious why that happened? it doesnt seem that there is any leaks or anything that i can tell from.
    then another question: i fill it up from the coolant cap (metal one) then does it overfill itself into the reseviour or do i stop when it gets full then pour more into the reseviour?
  2. Nov 30, 2009 at 6:04 PM
    08pretaco
    az
    To make an observation: the metal cap doesn't seem to want to come off it just turns 1/4 turn. And also there seems to be quite a lot of dry coolant on the top of the reseviour if that means anything?
    Also is it ok to mix the pink stuff with yelloew peak antifreeze?
  3. Nov 30, 2009 at 6:16 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    To answer your filling question, you should fill it up in the overflow reservoir and not into the radiator.
    If I remember right, when your coolant is hot it will push some of the fluid into the reservoir, and when it cool's off it will bring it back into the radiator. So this is why it changes.
    When you fill it up, make sure to use distilled water, or the radiator fluid from the auto parts store.
    EDIT: and also don't ever take off the radiator cap off when It's hot, it can push all of that hot water up at you. Wait for it to cool down.
  4. Nov 30, 2009 at 9:34 PM
    08pretaco
    az
    can you mix the factory coolant (pink) with say peak 50/50 coolant (yellow)
  5. Nov 30, 2009 at 10:05 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I would stick with the OEM coolant. They are about $15 a gallon from the dealership. I have read that other coolants can damage our engines, they have some chemicals that can damage our engines.
  6. Nov 30, 2009 at 10:10 PM
    08pretaco
    az
  7. Nov 30, 2009 at 10:12 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Do you have pics of your Tacoma?
  8. Nov 30, 2009 at 10:15 PM
    08pretaco
    az
    what kinda pics you looking for?
  9. Nov 30, 2009 at 10:18 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Any kind of pics is good. I like see pics of Tacomas, especially ones in AZ. I try too keep an eye for other TW members on the road.
  10. Nov 30, 2009 at 10:20 PM
    08pretaco
    az
    let me look around and ill post some up. theres some in the offroad section from mogollon rim but im sure i can scavange some more up
  11. Dec 3, 2009 at 6:13 PM
    08pretaco
    az
    thanks man i went to the stealership and they wanted to charge me 25 bucks im like f that man seriously? 25 bucks..15 bucks!
  12. Dec 3, 2009 at 6:36 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    sometimes you really got apply some force to get the cap off, also kinda push down on it as you unscrew it...but yeah, be careful when unscrewing the cap when the engine is hot
  13. Dec 3, 2009 at 6:55 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    when you fill it fill it in both the rad(metal cap)and in the overflow.there will be a line onthe overflow bottle that says full cold fill it to that line if the engine is cold.there will be another line that says full hot if you fill to this line when cold you will have a mess when it get's hot.
  14. Dec 4, 2009 at 11:03 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    If you are still above the low line why are you adding fluid??
  15. Dec 5, 2009 at 8:46 AM
    08pretaco
    az
    because i dont wanna forget about it then be out of coolant/antifreeze
    i cant get that damn cap off :mad:
  16. Dec 5, 2009 at 8:52 AM
    Clatrans243
    Clatrans243 Active Member
    Bill
    Albuquerque, NM
    2010 4X4 TRD Off Road
    Are all "red" coolants compatible with one another? I have a gallon of Mopar long-life stuff that I got for my wife's van; any reason why I can't use it in my Tacoma?
  17. Dec 5, 2009 at 9:03 AM
    Clatrans243
    Bill
    Albuquerque, NM
    I think they're designed that way to discourage owners from taking the cap off. That way we'll all add coolant only through the overflow reservoir the way we're supposed to.
    If you are really determined to take the cap off, try turning it counterclockwise until it stops, the 1/4 turn you mentioned earlier, and then push down real hard while you turn it counterclockwise even more. That's the way most of them work, but it's still best left alone unless you have a really good reason to remove it.
  18. Dec 5, 2009 at 3:14 PM
    tacoman101
    scott
    vermont
    yea you really gotta press down on the cap
  19. Dec 5, 2009 at 4:15 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    That sucks! Did you get the lid off?
  20. Dec 5, 2009 at 8:16 PM
    08pretaco
    az
    no i didnt get the lid off ill try the press down and rotate in the morning as it is hot right now. and they i got them down to 15 bucks!
