Coolant Reservoir Bubbling and Filling Up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mynameishigh, Jun 16, 2016.
  1. Jun 24, 2016 at 6:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    :thumbsup:
    Glad to have assisted getting you pointed in the right direction.
  2. Aug 26, 2018 at 1:57 PM
    IdRatherBNTheSanJuans
    IdRatherBNTheSanJuans Well-Known Member
    Coe
    05 TRD Sport 4x4 DCLB
    Kings. JBAs. AllPro standards. Mastercraft CXT 255/85r16s
    Older thread I know- but OP, is your truck still running good? Do you wish you had just replaced the whole motor with a lower mileage one?
    I have 205k on my truck, and got bubbles in my overflow as of today... Looking at what the my options are...
    Any pointers or gotchas you would share with someone following in your footsteps?
  3. Aug 26, 2018 at 5:26 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What Jimmy said,you can do all the tests you want,but the fact is you have a blown head gasket,a $3,000 fix.
  4. Aug 26, 2018 at 5:45 PM
    Muddinfun
    Muddinfun Well-Known Member
    The OP hasn't been around for almost a year, so not likely you'll get an answer.
    Personally, my opinion is if the motor has over 200K miles on it, it's not worth cracking open. Find a 60K mile motor in the wrecking yard and drop it in.
  5. Aug 26, 2018 at 6:11 PM
    Coe
    That's kind of what I'm thinking too... Darn it!
  6. Aug 26, 2018 at 9:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A weak radiator cap can let pressure out too easily,the reservoir will fill too fast and bubble. Try a new cap
  7. Aug 27, 2018 at 12:50 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I would certainly replace the head gaskets on a 205K motor if I was familiar with the engines maintenance and use history. What are the compression numbers? (obviously one or more cylinders won't be accurate but it will give you a general idea). Has it been taken care of? Oil changes done regularly, etc.? 'Low mileage' motors don't mean much to me without a history or some pre-purchase mechanical testing. Common sense is a good guide here.
  8. Aug 27, 2018 at 12:51 PM
    Coe
    Didn’t even think of that… I’ll give that a shot! That would be awesome!
    I agree with you… Unfortunately, I don’t really know the history of this motor. I’ve only had it for about 1500 miles, but it seems to run really good, and my last several tanks I’ve been getting about 17 MPG‘s, and it doesn’t feel weak. This is my third Tacoma, so I’m a little familiar with what they should feel like.
    If the radiator cap doesn’t fix it, I’ll run a compression test before I buy another motor. Just to see what the numbers are. Then go from there.
  9. Aug 27, 2018 at 1:02 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    a higher pressure cap isn't going to help since the engine can develop 200+ PSI when running
    2005-2006 have been known to have leaking HG
    Bubbles most of the time in coolant is head gasket, cracked head or block
    Sorry but there is no easy button to fix this
  10. Aug 27, 2018 at 1:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    200 psi!! You mean when a headgasket problem is present I hope.
    200 psi would blast hoses apart and crack every plastic component in the cooling system!
    He doesn't know if he has a headgasket problem yet, hence the recommendation to simply try a new cap first
    IdRatherBNTheSanJuans likes this.
  11. Aug 27, 2018 at 1:35 PM
    knottyrope
    Knotty
    Bahstun
    Yes that s what I mean. Combustion pressures are nothing to sneeze at.
    Yes 200 would burst things but that wont happen if the cap will release pressure below it
  12. Aug 27, 2018 at 2:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm not sneezing at combustion pressures. Yes it's probably a headgasket failure.. but what if it's not? A 15 dollar rad cap would be worth it just to be sure before he pulls the trigger on a head job or maybe gets rid of the truck.
    After all, he is using the internet to diagnose a problem;)
    Lester Lugnut likes this.
  13. Aug 27, 2018 at 3:55 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Also a compression test won't tell you anything. You need to do a leakdown test.
  14. Aug 27, 2018 at 5:46 PM
    Coe
    I figured it would likely tell me what cylinders the gasket is shot between, and also some kind of idea what kind of shape the rest of the motor is in... Which would help me decide whether to replace the head gaskets or swap the motor.
    I'm really not trying to diagnose over the internet... I figured what it likely was as soon
    As I saw the bubbles.
    I haven't had a chance to pull out my hydrocarbon test kit yet... Maybe tonight..
  15. Aug 27, 2018 at 6:26 PM
    #35
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    A compression test just isn't very accurate. The motor has to be in poor shape to get bad compression test readings and would never rely on it to diag the condition of the motor. Using a leak down tester will pump air in the cylinder which can reveal small head gasket leaks that a compression test would miss.
  16. Aug 27, 2018 at 9:02 PM
    #36
    Coe
    Don’t disagree. I just happen to have a compression tester in my toolbox and not a leak down tester.
    I need to add that to my collection at some point!
  17. Aug 27, 2018 at 9:20 PM
    #37
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Easy, got an auto parts store, buy an adapter to connect a shop air compressor to spark plug hole. Pull plug on cyl 6, connect air compressor, turn on air compressor, turn crank to close valves, what coolant bubble.
    Or buy a $20 USB endoscope on eBay, pull plugs, put Cam in holes, cyl 6 piston will look clean, the rest have carbon build up.
    Coolant pressure test WILL NOT diag head gasket failure in 1GR-FE.
    This is what is happening.
    Small amounts of exhaust gases are dealing into the coolant system. When you run tests
    You are burping the coolant system. Removing the air bubbles.
    It's a hairline crack in head gasket, a well known factory defect.
    It takes about 2-3 days of normal driving for enough gases to get into the coolant system to cause over heating.
    Now... On the highway, at highway speed, the air flow is keeping the engine cool enough to not over heat. Once you exit the highway, the airflow stops, you have a few minutes before over heat.
    Trust me, head gasket us bad. If you need help with further diag let me know.
    #37
  18. Aug 27, 2018 at 9:23 PM
    #38
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Nope! Not on 2004-2006 manufactured 1GR-FE, coolant pressure test WILL NOT push coolant into the cyl! This is first hand real world, doing the tests myself. You have to pressurize the cylinder, air will escape into coolant.
  19. Aug 27, 2018 at 9:25 PM
    #39
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Compression test, again, not going to show bad head gasket, mine tested 180 on all six cylinders on dry compression test.
  20. Aug 27, 2018 at 9:27 PM
    #40
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Next time you have bubbles or over heat. Let it sit overbight. when you start it, have someone listen under the glove box for a water rushing sound.
