Coolant Reservoir Bubbling and Filling Up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mynameishigh, Jun 16, 2016.
  1. Sep 11, 2019 at 11:55 PM
    #81
    Justintheegreat
    Justintheegreat Well-Known Member
    Northern CA
    06 DCSB Sport
    Nothing in this life is free lol.
  2. Nov 27, 2019 at 8:14 AM
    #82
    tomjo1
    tomjo1 Well-Known Member
    Tomjo
    Taiwan
    2007 Black Tacoma Sport
    2.5inch high life kit
    Seems i got same issue now ...
    one question , when you replace head gasket , did they polishing the head to make it smooth ?
    Heard lots of when head gasket broken , will made head deformation .....
  3. Nov 28, 2019 at 5:44 AM
    #83
    tomjo1
    Tomjo
    Taiwan
    Hey
    For FIPG , can use this to instead ?
  4. Nov 28, 2019 at 9:18 AM
    #84
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    I had toyota do the head gaskets and they machined the heads. Timing is just fine and i got my power back.
    It is a big job so i let toyota handle it. Plus they gave me a free loaner car.
  5. Dec 1, 2019 at 6:42 AM
    #85
    tomjo1
    Tomjo
    Taiwan
    Thats good news !!
    Ray1989 likes this.
  6. Dec 1, 2019 at 2:45 PM
    #86
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    expensive but the truck has been solid ever since
    tacomakid96 and DG92071 like this.
  7. Dec 1, 2019 at 5:06 PM
    #87
    tomjo1
    Tomjo
    Taiwan
    Yes , hope mine can be back have no any issue .
  8. Dec 2, 2019 at 8:28 AM
    #88
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    i have put 2400 miles on it in the last 2 weeks and have had no issues.. yet ha
    tacomakid96 likes this.
  9. Dec 2, 2019 at 3:52 PM
    #89
    tomjo1
    Tomjo
    Taiwan
    :bananadance::bananadance: Thats good !
  10. Dec 2, 2019 at 6:36 PM
    #90
    jorgem
    jorgem Well-Known Member
    I used Ultra Grey on timing cover when I did my head gasket last year
    No leaks after 15,000 mikes
    Just clean surfaces extremely well and use a thin layer on both sides, allow to dry overnight.
  11. Dec 2, 2019 at 7:16 PM
    #91
    tomjo1
    Tomjo
    Taiwan
    Noted and thanks for your feedback ^^
  12. Dec 4, 2019 at 6:14 AM
    #92
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    What is the conversion rate of Mikes to Miles?
  13. Dec 4, 2019 at 5:40 PM
    #93
    tomjo1
    Tomjo
    Taiwan
    I think should be Miles XDDD
  14. Dec 21, 2019 at 5:46 PM
    #94
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    When you say "machined", you are referring to valves and ports, not actually milling the surface.... right? Hopefully.
  15. Dec 23, 2019 at 12:28 AM
    #95
    tomjo1
    Tomjo
    Taiwan
    If it's mean milling the surface , will get any impact about this ?
  16. Dec 26, 2019 at 8:38 AM
    #96
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Not exactly sure... I assumed toyota knew what they were doing..
  17. Dec 26, 2019 at 8:46 AM
    #97
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Toyota has specs as to how much can be milled off a cylinder head if it falls within that spec there are zero issues.
    12TRDTacoma and b_r_o like this.
  18. Jan 1, 2020 at 11:46 PM
    #98
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    Just want to cast another vote in favor of replacing head gaskets on the early 4.0s. Mine ('05) took me several weeks of part time effort in my driveway, and I also took the heads in for a valve job at a machine shop. Not sure if they resurfaced them, or just reseated the valves, but compression went up to by about 10 psi per cylinder, to 180-188 psi -- and crucially, there are no more bubbles in the coolant! I also got new head bolts, new hoses, a new radiator, a new water pump, a new thermostat, and new gaskets for everything I disassembled. And it all cost $thousands less than the lowest bid I got from a shop, even after buying some specialty tools and a big-ass impact driver. The trade-off was enduring day after day of hellish physical labor and crushing self-doubt throughout the entire process.
    I used the Toyota black FIPG around all the oil seals, and blue Permetex around the water passages, since the Toyota spec'd coolant-compatible sealant was prohibitively expensive. I have had zero leaks since.
  19. Jan 2, 2020 at 9:11 AM
    #99
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Well done! I am glad this post is helping people!
  20. Jan 4, 2020 at 10:52 PM
    #100
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    X2 well done bro!!!!!
