Coolant reservoir hose leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shawnmsx33, Jan 25, 2019.
  1. Jan 25, 2019 at 10:09 PM
    Shawnmsx33
    Shawnmsx33 [OP] Active Member
    Shawn
    Oregon
    2012 Tacoma SR5
    Hi guys, my 2012 SR5 is leaking a few drops of coolant from the hose where it meets the bottle, Sounds like this is a pretty common issue, just snugg a clamp down over it and be done?
  2. Jan 25, 2019 at 10:11 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Sounds like a reasonable solution.
  3. Jan 26, 2019 at 4:53 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Had the same issue with my truck last year. I disconnected the hose from the tank, cleaned the dried anti-freeze off, lightly scuffed the mating surface of the tank nipple with a Scotch-Brite pad, then put the hose back on with a new clamp. Problem solved.
  4. Jan 26, 2019 at 5:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A zip tie pulled tight also works well.
    inwood customs likes this.
  5. Jan 26, 2019 at 5:54 AM
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    I used one of those spring clamps that comes with fuel filters on mine. If you use a screw clamp, be careful not to over tighten.
    TheDevilYouLove likes this.
  6. Jan 26, 2019 at 8:38 AM
    Shawnmsx33
    Shawn
    Oregon
    2012 Tacoma SR5
    Thanks guys, I’ll get on it!
  7. Jan 30, 2019 at 7:49 PM
    Shawnmsx33
    Shawn
    Oregon
    2012 Tacoma SR5
    I clamped the hose today, haven't driven it yet to see if it is leaking, but I started thinking, why is the radiator kicking coolant into the overflow to begin with? Is that normal with this radiator system? The other thing I was wondering is if the vent hole under the cap on the overflow is where the droplets are coming form, any thoughts?
  8. Jan 30, 2019 at 8:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    When the coolant gets hot it expands and the extra fluid goes to the overflow tank. When it cools off and contracts it takes fluid from the overflow tank.
    Too Stroked likes this.
  9. Jan 30, 2019 at 8:19 PM
    Shawnmsx33
    Shawn
    Oregon
    2012 Tacoma SR5
    Right, so this is normal, I was under the impression the coolant overflow was only used if there was some other issue with the radiator not being able to contain the coolant, Excuse my ignorance haha.
  10. Jan 30, 2019 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes completely normal.
  11. Jan 31, 2019 at 4:57 AM
    mshultz
    Michael
    Wooster, Ohio
    Barcelona Red
    In the old days radiators were not completely filled with antifreeze. There was an inch or two of air space for the coolant to expand when hot. The air did not just stay at the top of the radiator, it circulated throughout the cooing system and reduced the effectiveness of the system. It also increased corrosion as the oxygen in the air reacted with the coolant and the metals in the system.
  12. Jan 31, 2019 at 5:02 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Mine did the same thing. I replaced the hose with a new silicon hose and put a band clamp on it. As has been stated, do not over tighten.
