Coolant reservoir looks odd please help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Josephgobelko, Feb 23, 2023.
  1. Feb 25, 2023 at 5:49 AM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    No, he needs to do a coolant system leak/pressure check now. If the head gasket completely fails (and it is likely in that process now of complete failure) it will be much more expensive than the check. And engines have a way of failing at the worst time, like on a freeway, surrounded by vehicles going 10 over, no exits and no place to pull over. The 05 and some (early) 06 are known to fail, it is a real problem and there should have been an SB. JFYI, my engine ran fine, never missed a beat until, boom!
    If you get a CEL or all of the lights come on the instrument cluster, get off the road and shut it down NOW if at all possible! And call a tow truck. My CEL came on and then in short order everything came on and then the engine rapidly overheated before I could find a safe place.
  2. Feb 25, 2023 at 10:50 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    Agree with the recommendations on this thread and that it's better to be cautious than to "hope" it's not a head gasket problem.
    You can also take a tissue and hold it a couple of inches away from the exhaust (with the engine running) and see if any sweet-smelling moisture gets deposited on the tissue. Coolant tastes and smells sweet and is poisonous if ingested. If you get a hint of coolant on the tissue, you have another early indication that you have a head gasket problem.
  3. Feb 25, 2023 at 12:48 PM
    Waasheem
    Waasheem
    2007 xrunner
    Stick with this plan
    Jerry311SD, jackn7 and TnShooter like this.
