Coolant Snafu help!
Discussion in 'Technical Chat' started by MikeD23, Apr 28, 2020.
  1. Apr 28, 2020 at 2:30 PM
    MikeD23
    MikeD23 [OP] New Member
    Hi All, Might have done something really stupid. I was doing a coolant drain and fill and filled just a little too much. No worries I thought and grabbed my hand pump. After pumping some out I realized the last thing I had used the pump for was gear oil. It had been wiped down beforehand but I can now see a slight oil sheen on the surface of the coolant in the reservoir. How big of a deal is it to have this trace amount of oil in there?
  2. Apr 28, 2020 at 3:28 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I wouldn't worry about either one, little too much, or the slight sheen, but wait a while and someone will tell you that a drain and double flush is the only way your going to avoid major damage.
    Wyoming09, MikeD23[OP] and whatstcp like this.
  3. Apr 28, 2020 at 4:18 PM
    MikeD23
    If I were a smart man I would have drained it from the plug to begin with. However, I am not a smart man. I did do that after it had already been ran. Hoping not too much from the reservoir circulated during that 5 minute drive. Thanks for the replies guys, I appreciate it.
    Biscuits likes this.
