coolant temp guage above half.....normal???
Discussion in '1st Gen. Tacomas (1995-2004)' started by jesse12508, May 18, 2009.
  1. May 18, 2009 at 5:20 AM
    jesse12508
    jesse12508 [OP] Member
    beacon,NY
    extended cab,3.4,auto,stock
    hello,i just purchased a 2002 tacoma with the 3.4l v-6,auto trans.as ive owned 9-10 toyota pickups,this one is the first to have the coolant temp guage running right ABOVE half,all other trucks temps ran BELOW half.truck had 119,000 on it.i did a coolant flush and fill w/new t-stat 180 degree and new radiator cap.still running right above half.no change.is this normal???....also,there are no coolant leaks,i let truck run with rad. cap off topping off coolant occasionally so im sure there is no air in the system(i also was told by a friend to pull upper rad hose off and fill from it as well as radiator)
  2. May 18, 2009 at 5:51 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The OEM gauges aren't exactly 'precision instruments'. If it consistently stays in the vicinity of the half-way point (plus or minus) I wouldn't worry about it - assuming there are no other symptoms and it doesn't vary from that orientation.
  3. May 18, 2009 at 5:54 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    +1
    My truck's guage is always dead center, but I've had cars in the past that were just a touch above mid-way. They never moved, and I never had a problem w/ the car. If it's consistently in the same place, I'd consider it normal.
  4. May 18, 2009 at 6:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to run a scan gauge to your OBD port and see what the temp is while driveing.
  5. May 18, 2009 at 6:38 AM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    I have a 2001, 4cyl 5 spd that does the exact same thing. I did a fluid flush, put in a new 180f thermostat and it it just a touch higher than center. But it does not move from there. Glad I'm not the only one with a wanky gauge. it was this way before I did the flush and thermostat as well. So I guess that's just how it is.
    Cheers.
  6. May 18, 2009 at 6:43 AM
    jesse12508
    beacon,NY
    thanks guys,at this point im gonna assume its operating in the normal temp range
  7. May 18, 2009 at 8:57 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    My 2003 has run slightly above dead center since '05 when I purchased and I have never seen it move up or down... I would say it's running at normal operating temp.
  8. May 18, 2009 at 9:39 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    These instruments are seldom very accurate intentionally. I have an old 55' Mercury and the gauge on that thing swings from 140-190 degrees all the time. Today that would freak people out. Thus if the engine is operating at an acceptable level, the gauge generally stays "somwhere" in the middle. I would not worry about it period.
