Coolant temp issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by rhitt3027, Oct 5, 2017.
  1. Oct 5, 2017 at 6:52 AM
    rhitt3027
    rhitt3027 [OP] Active Member
    2004 tacoma with 2002 2.7l motor
    what would make my temp go down when the A/C is on and go up when the heat is on??
  2. Oct 5, 2017 at 8:08 AM
    Glamisman
    Glamisman Well-Known Member
    the thermostatic coupler on the cooling fan... when the AC is on additional heat is pulled through the radiator from the AC condensor and this triggers the cooling fan to lock up slightly more, if that makes sense.
  3. Oct 5, 2017 at 8:14 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    A/C on also increased the idle RPM, providing more cooling while stopped or slowly moving.
  4. Oct 5, 2017 at 7:21 PM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    What they said.
  5. Oct 5, 2017 at 9:48 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    How are you monitoring your coolant temp? Stock gauge or some other type of reader? It does sound like your fan clutch might be getting tired, but if you are running your heater on high with the fan blowing full blast, your coolant temp should drop.
    Start with the simple things and check your coolant level. Also, check the condition of your radiator cap. The OEM caps are known to fall apart and drop a spring and a plastic cap inside the radiator. A compromised cap won't hold the proper pressure on the cooling system. If the cap and coolant level are fine, I'd check the function of the fan clutch.
    Here's a video showing how you can test your fan clutch:
    <iframe width="560" height="315" src="https://www.youtube.com/embed/WzhlACxqeqQ" frameborder="0" allowfullscreen></iframe>
  6. Oct 9, 2017 at 4:48 PM
    rhitt3027
    I just replaced the cooling fan about a month ago, but as soon as I turn the truck off and if I just turn the key right back to acc the gauge is reading in the middle where it should normally run
