Coolant temp monitoring solution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomasandsalsa, Nov 13, 2020.
  1. Nov 14, 2020 at 10:53 PM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
  2. Nov 15, 2020 at 2:42 AM
    Tacomasandsalsa
    Tacomasandsalsa [OP] Active Member
    Texas
    2010 TRD TACO
    How accurate do you guys think the OEM temp gauge is? I have not heard to many good things about them they seem to be pointless.
  3. Nov 15, 2020 at 3:14 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  4. Nov 15, 2020 at 5:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    wi_taco, DaveB.inVa, ABNFDC and 4 others like this.
  5. Nov 15, 2020 at 5:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I thought that was an odd statement myself. o_O
    Torspd and 12TRDTacoma like this.
  6. Nov 15, 2020 at 5:09 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    It is my understanding that the water temp gauge in the Tacoma is a "buffered" gauge. The gauge is controlled by the IPC. The ECU does read actual water temps, available through the OBD port, but the IPC buffers the signal to the OEM gauge.....Cold < 90F (needle pointing at C) operating temp (needle in the middle) 120F - 230F, Hot 230F - 260F (needle moves to H). Under some driving conditions, it is prudent to actually know what water, oil and trans temps are to avoid catastrophic damage.
    oledragoon likes this.
  7. Nov 15, 2020 at 7:32 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    fwiw I use OBD fusion and a $10 obd2 reader from Amazon to check up on my f250 diesel temps and I like it. This is towing a load, ect should be around 190f unloaded.
    m00seNUckLEz likes this.
  8. Nov 15, 2020 at 8:58 AM
    eon_blue
    Azusa, CA
    ...how? Coolant temp/water temp = engine temp. An overheating engine can go all kinds of damage
    Alexely999 likes this.
  9. Nov 15, 2020 at 9:42 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Yeah, it’s that brief moment in time when coolant temp rises abnormally that might let you know to shut it down before permanent damage is done.
    eon_blue[QUOTED] likes this.
  10. Nov 15, 2020 at 10:18 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I have the Ultragauge and I love it.
    Jimmyh likes this.
  11. Nov 15, 2020 at 11:32 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Other than 2005/2006 models with head gasket leaks, stock 2nd gen cooling system isn't prone to problems. @Tacomasandsalsa's attention would be better focused on known problem areas, like transmission fluid temps and power steering fluid temps.
    Other mfrs like Subaru have deleted the coolant temp gauge altogether, replacing it with two lights in the instrument cluster: blue light when the coolant is cold, red light when it's overheating, and no light at normal operating temperature.
  12. Nov 15, 2020 at 10:19 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Fine, but that isn't what you said:
    Torspd likes this.
  13. Nov 15, 2020 at 10:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I stand by what I said. Coolant temp isn't going to be the thing that'll hurt his truck. It'll be transmission temp, power steering temp, rear diff temp (on the undersized 8" e-locker diff)..
  14. Nov 15, 2020 at 11:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm glad your crystal ball is working.
    It is ludicrous that you think engine/coolant temperature doesn't need to be monitored.
    But do carry on.
    wi_taco likes this.
  15. Nov 15, 2020 at 11:46 PM
    #35
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Rear diff temp??? Your credibility just evaporated.
    Torspd likes this.
  16. Nov 16, 2020 at 2:21 AM
    #36
    bagleboy
    Scott
    Norcal, Santa Rosa
    I miss having complete gauge clusters. Coolant temp is a critical indicator of whether a vehicle is operating normally or not and an indicator light has no nuance of information, it’s just a logic gate. Even being accustomed to how quickly it comes up to temp allows changes in that to inform me. The data is being collected so it would be nice to have it available through instrumentation. The entune system could easily handle the display.
  17. Nov 16, 2020 at 2:57 AM
    #37
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
  18. Nov 16, 2020 at 7:23 AM
    #38
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Toyota kept the same size e-locker diff between 1st gen and 2nd gen while upping the weight and power significantly, so its durability is marginal. Why do you think Toyota went to a 8.75" e-locker diff on 3rd gens? Unfortunately there's no OBD2 data PID, so it just does its thing silently until it blows and strands you, while you stare at coolant temp numbers that don't change much.
  19. Nov 16, 2020 at 7:31 AM
    #39
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    ScanGauge II for sure. You can program trans temps in there as well if you wont to monitor those
  20. Nov 16, 2020 at 12:11 PM
    #40
    Sharpish
    Brian
    Except Toyota differentials are very durable and you rarely hear of failures that weren’t caused by tomfoolery.
    Jimmyh likes this.
