Coolant temp sensor
Discussion in '4 Cylinder' started by TYetti, Mar 19, 2019.
  1. Mar 19, 2019 at 12:13 PM
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Searching around can't find the answer.. hoping for a quick yay or nay. I'm running an aftermarket temp sensor on my new engine build 09 2trfe for reference. If I don't put the OEM temp sensor back in is this thing gonna freak out and not run right ? I can maybe come up with some contraption but having to source metric fittings is a friggen nightmare. I have the engine out Id really hate to find this out later cause it's a bitch to get at when the engine is in the truck
    Cheers
  2. Mar 19, 2019 at 12:14 PM
    TYetti
    Mat
    Ps
    I don't care if the idiot gauge on the dash doesn't work
  3. Mar 19, 2019 at 12:37 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    ECU adjust many things based on coolant temp. I can guarantee your aftermarket temp sensor has a different calibration than the stock sensor. You really do need to reinstall it
  4. Mar 19, 2019 at 12:38 PM
    TYetti
    Mat
    I wasn't sure if they read from the same location FML what a nightmare this is
  5. Mar 19, 2019 at 12:39 PM
    05Taco4x4
    2TR-FE Enthusiast
    Are you running an aftermarket ECM or stock? Is this thing boosted?
  6. Mar 19, 2019 at 12:42 PM
    TYetti
    Mat
    It's stock well it's now bored .20 over with better pistons and rings, but that's not really the point the point is the massive failure that is the OEM lack of gauges, Im trying to get accurate readings so I can better monitor how the engine is performing
  7. Mar 19, 2019 at 12:43 PM
    05Taco4x4
    2TR-FE Enthusiast
    If you're looking for another spot to get an accurate reading, put a tee in line at the No1 bypass or swap a sensor for the coolant drain cock on the passenger side of block.
  8. Mar 19, 2019 at 12:46 PM
    TYetti
    Mat
    Oooo that's an idea.. I have an adapter for the head it took 2 hrs to find one cause it's metric to non metric.. the no 1 bypass is plastic so that's not gonna work. But I like that drain idea
  9. Mar 19, 2019 at 1:03 PM
    05Taco4x4
    2TR-FE Enthusiast
    I was referring to tube at back of it. I’d highly suggest swapping to the metal one
  10. Mar 19, 2019 at 2:21 PM
    TYetti
    Mat
    There's no tube on the back of the block.. yes I'm not impressed fresh engine hey let's reuse this shitty plastic piece.. I didn't know they'd changed the design to metal. Luckily the auto meter sensor fits into the drain tube. Yes it seals. I removed the tube from the block and filled it up with water to see if the sensor would allow water to pass by the sensor tip. So no need to waste another 2 hours looking for metric fittings
    05Taco4x4[QUOTED] likes this.
  11. Mar 19, 2019 at 6:51 PM
    05Taco4x4
    2TR-FE Enthusiast
  12. Mar 19, 2019 at 6:53 PM
    TYetti
    Mat
    Ya I called the local dealership, theyll have me one tmrw.. super easy to do when the engine is out of the truck. The builder didn't know they made a change so he just cleaned and reused the old pipe cause it didn't have any signs of wear.. I'm not taking chances
  13. Mar 19, 2019 at 7:00 PM
    TYetti
    Mat
    The OEM oil pressure sender is still attached to the harness it's fused on with dirt lol
  14. Mar 19, 2019 at 7:45 PM
    05Taco4x4
    2TR-FE Enthusiast
    That oil pressure sender looks nothing like mine
    83530-0E010
    I replaced my Air Switching valve about a year ago, I removed it because I have a turbo now.
    If you'd like to pick it up, I'd let it go for $70USD + shipping (not sure how much that would be).
  15. Mar 19, 2019 at 7:46 PM
    05Taco4x4
    2TR-FE Enthusiast
    Looking good, got the LCE header :thumbsup:
  16. Mar 19, 2019 at 7:50 PM
    TYetti
    Mat
    It's an autometer unit, my OEM unit is fine, I just need to thread it back in when the engine is in the truck..
  17. Mar 19, 2019 at 7:57 PM
    TYetti
    Mat
    I've got a magnaflow pro exhaust to go on top along with the Lce pro clutch need this thing back together
  18. Mar 20, 2019 at 5:30 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I have the LCE exhaust and header on my truck. Be prepared, it's loud as fuck. I had a 12" Vibrant resonator welded in to quiet it down enough that I could actually drive it.
