Coolant temperature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Apr 7, 2025.
  1. Apr 7, 2025 at 8:29 AM
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    I have an issue with my 2008 tacoma 2.7
    My coolant temperature increases on the highways up to 230F but at normal cruising it will be normal like 194F
    I have replaced the fan clutch and the thermostat but still the same .. could it be bad water pump? How i can tell if it’s bad?
  2. Apr 7, 2025 at 10:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Possibly the thermostat...
  3. Apr 7, 2025 at 10:20 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The water pump either works or it doesn't, if your heater works then the water pump is working.
    I have in rare instances seen the impeller separate from the shaft on a water pump but that typically results in it quickly overheating all the time.
    You could possibly have a low coolant level, air trapped in the cooling system, radiator is getting restricted, thermostat not opening all the way, or a headgasket that is starting to leak combustion gases into the cooling system.
    Tatts521 and Steves104x4 like this.
  4. Apr 7, 2025 at 11:30 AM
    Neticstacoma
    It has a new thermostat, is there a different types of OEM thermostat?
  5. Apr 7, 2025 at 11:33 AM
    Neticstacoma
    just now i went to check, the coolant is top there is no leak then I opened the cap to check if there are any air or gases i kept the car running up to 164F and kept pressing the hoses because there were no bubbles coming but after pressing the hoses very little small bubbles came (while pressing only) I noticed the thermostat hose side very hard is that normal ? Meaning the thermostat thermostat is closed?
  6. Apr 7, 2025 at 11:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try using a foaming cleaner on the outside of the rad then rinse from the backside bottom up. I stood there for 13 minutes watching a river of chocolate milk run down the driveway. Don’t know but good luck!
    BlkDakDave likes this.
  7. Apr 7, 2025 at 11:52 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If the truck spends any amount of time in muddy conditions Id start with a rad cleaning, like mentioned above. Garden hose clean water back to front.
  8. Apr 7, 2025 at 9:54 PM
    Neticstacoma
    Thanks guys I’ll try cleaning the rad today and see what happens
    Steves104x4[QUOTED] likes this.
  9. Apr 8, 2025 at 5:12 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    If your radiator cap is original you should replace that also.
    Steves104x4 likes this.
  10. Apr 8, 2025 at 2:31 PM
    Neticstacoma
    just recently I replaced it like a month ago
  11. Apr 14, 2025 at 2:15 AM
    Neticstacoma
    I did cleaning / flushing and it still the same
  12. Apr 14, 2025 at 2:16 AM
    Neticstacoma
    Help please
  13. Apr 14, 2025 at 3:40 AM
    Neticstacoma
    Could it be bad engine belt?
  14. Apr 14, 2025 at 8:26 AM
    Neticstacoma
    Please anyone
  15. Apr 14, 2025 at 8:27 AM
    SR-71A
    Zack
    Southern Maine
    Did you clean the radiator as suggested?
  16. Apr 14, 2025 at 9:14 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    makes me wonder if the radiator is clogged.
    I asked an AI: A car overheating at highway speeds often indicates an issue with the cooling system's ability to dissipate heat effectively, especially when the engine is working harder and generating more heat. Common causes include a radiator issue, a bad thermostat, a leaking cooling system, or a faulty water pump.
  17. Apr 14, 2025 at 10:20 AM
    Neticstacoma
    Thank u Yes i did, the only difference after the cleaning that now it takes little bit more time to reach that high temperature
  18. Apr 14, 2025 at 10:23 AM
    Neticstacoma
    thank u for your reply, the thermostat is new recently have been replaced, about the leaking I doubt that because the water level is the same not reducing, how can I know if the issue is with the water pump?
  19. Apr 14, 2025 at 11:15 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I don't see it being the thermostat since the symptoms didn't change at all with a new thermostat. I'm thinking the radiator core is clogged, not the fins being clogged with dirt. If it had been dirt it'd likely be noticeable immediately after leaving the the place that filled the fins with enough crap to impede airflow. If it the same thing had occurred over time you'd have seen a temp problem that slowly escalated as dirt built up. Radiator probably needs replaced or boiled out.
  20. Apr 14, 2025 at 11:39 AM
    Neticstacoma
    so you don’t think it’s a water pump problem?
