Coolant temperature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Apr 7, 2025.
  1. Apr 14, 2025 at 12:07 PM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    How many miles do you have? As it was mentioned earlier its rather unlikely its the water pump since they generally either work or not at all. Not to throw parts at it but if you're at any reasonable number of years/miles it may just be time for a cooling system overhaul. Radiator, hoses, water pump and thermostat, maybe even fan clutch. None of them are overly expensive and somewhat easier to change all at once. Not sure what you used for previous parts but should stick to OEM / AISIN for thermostat, water pump, fan clutch and OEM / DENSO for radiator. Maybe you have a defective thermostat that is not opening all the way, to me it sounds like that or the radiator is clogged.
    ridefreak likes this.
  2. Apr 14, 2025 at 12:13 PM
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    the thing is that recently i replaced my engine so it has around 50-60k miles , the earliest engine had a new water pump but I am not sure if the guy had put my water pump or no, I forgot to mention but i recently replaced the clutch fan and the radiator cap as well
  3. Apr 14, 2025 at 12:18 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    so what is normal driving? in my world, highway is included in normal.
    i think it sounds like a partially blocked radiator.
  4. Apr 14, 2025 at 1:22 PM
    Neticstacoma
    Normal driving meaning inside the city low speeds, I guess I will start with replacing the radiator with the hoses cus i flushed the radiator and not much difference
  5. Apr 14, 2025 at 2:02 PM
    aficianado
    back to bone stock.
    i have bought a thermostat that was defective. have you ever tested one in hot water with a thermometer? but in my brain, i think if it was the t-stat, it would get hot in any driving condition.
  6. Apr 14, 2025 at 2:05 PM
    aficianado
    back to bone stock.
    how do you know your actual temperatures? you have a real gauge? i cant remember my gauge in my 2006. i dont recall it having hatched numbers.
    SR-71A likes this.
  7. Apr 14, 2025 at 3:07 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The radiator can also be reconditioned but these days it almost doesn't pay as cheap as radiators are/were recently:)
  8. Apr 14, 2025 at 3:12 PM
    Neticstacoma
    i have a scan gauge
  9. Apr 14, 2025 at 3:15 PM
    Neticstacoma
    I thought I’ll check how much to get a new one if it’s way expensive maybe I’ll recondition the one that i have and test it but honestly I feel like much better to get a new one
  10. Apr 14, 2025 at 3:17 PM
    Neticstacoma
    yea I don’t think its the thermostat cus it only gets hot on the highways ( around 59F increases)
  11. Apr 15, 2025 at 7:15 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    The shop that installed your used engine is very unlikely to have swapped your water pump onto it.
    You still haven't mentioned the thermostat brand, or the brand for any other parts like fan clutch and radiator cap which if it isn't from Toyota or the OEM manufacturer for that part (AISIN/DENSO etc.) I wouldn't rule that possibility out. A thermostat isn't only open or closed, it should start to open at XX rated temp, and continue to open more until its fully open at a certain max temp. It's possible yours is defective and opening a bit but not enough coolant flow to keep up with higher loads. This was also all pretty much mentioned in the first responses.
    Not to come off wrong but it's your truck and none of us are physically there, so we can't always just give a definitive its this replace it and you'll be all set. Details and a timeline are important for diagnosis. I might have missed it but you didn't explain much details about how long its been happening, if it was sudden vs over time, if it happened after fan clutch and thermostat, or if that was a first effort to fix the problem. How recent is "recent", give number of miles on truck, and since engine replaced how many miles did that engine have and how long ago was it swapped. Have you been losing coolant, are there any signs of head gasket leaks, etc. etc. Diagnosis is much harder without having the whole picture.
    Torspd and SR-71A like this.
  12. Apr 15, 2025 at 9:56 PM
    Neticstacoma
    Thermostat is oem
    Radiator cap is oem
    Clutch fan is AISIN
    to be more accurate i used to have the same temperature issue with the older engine as well but it was happening on more higher speed around 90mph and more but now no even on lower speed on the highway around 70 mph it will start increasing
    the older engine had 183k miles
    The new engine i bought and it has around 60k miles and I added 3k miles on it , the temperature issue was there immediately after I took the car from the workshop and test it
    The is zero loss in coolant I don’t think it’s leaking somewhere
    Peter603Taco[QUOTED] likes this.
  13. Apr 16, 2025 at 3:58 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    You said you felt the rad hoses with the truck on and they had pressure, so I am disinclined to think water pump.
    It's sounding more and more like a clogged radiator. If the problem had started before the new engine, the swap could very well have shaken loose more junk and made the clog worse. If you have or can jimmy up some fittings, you can try to flow test the existing radiator with a garden hose, but it would be eyeball at best unless you have pressure meters for either end.
    I would hot water test the thermostat just to be sure, and if that's good, if it's my truck, I'm sucking it up and putting in a new OEM or CSF rad.
    herecomesace and SR-71A like this.
  14. Apr 16, 2025 at 5:29 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I would probably just replace the thermostat first with an OEM one to ensure it's working properly. If the problem persists, swap the radiator. When my radiator needs replacing, I'll probably spend a little more for an "all metal" radiator from a manufacturer like Mishimoto.
  15. Apr 16, 2025 at 6:46 AM
    #35
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Very first post he says he has replaced it already. A few posts above he says its OEM, kinda doubt thats the issue at this point.?
    ridefreak and Peter603Taco like this.
  16. Apr 16, 2025 at 6:50 AM
    #36
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Forget the thermostat, it's extremely unlikely that if this was a thermostat issue that it would have the SAME SYMPTOMs after replacing it with a new OEM thermostat or even a new NON OEM one for that matter.
  17. Apr 16, 2025 at 8:23 AM
    #37
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Then my recommended first step is complete. Questions?
  18. Apr 16, 2025 at 8:46 AM
    #38
    Neticstacoma
    Thank u guys for your feedbacks, now I will replace the radiator and hopefully solve this issue.. I will update u once I replace it and test it on the highway couple times
    Steves104x4 likes this.
  19. Apr 16, 2025 at 9:17 AM
    #39
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Yeah having all that information laid out makes it a lot clearer. Based on the fact that it was present with both engines strongly suggests something on the chassis side (radiator, clogged hoses or heater core maybe, etc.) Like said above, OEM/DENSO rad is a great next choice to hopefully resolve it for pretty short money, at 183k (assuming original) it's not a bad thing to do anyways. I don't have any experience with aluminum aftermarket rads at least on tacomas.
  20. Apr 16, 2025 at 9:23 AM
    #40
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    When the engine is at operating temp or maybe starting to overheat, check the temp of the upper and lower rad hose. If the top is screaming hot and bottom ambient then your rad is plugged. The lower of course should be much cooler but still fairly warm.
