Coolant temperature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, Apr 7, 2025.
  1. Apr 16, 2025 at 10:18 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So is the the hose above still "very hard" after the thermostat has opened? When compared to the lower hose.
    Do you have any accessories blocking the radiator, or is the front of the truck all stock?
    At idle, the fan keeps the engine cool. At speed, the air flowing through the radiator is primary cooler.
    Peter603Taco likes this.
  2. Apr 17, 2025 at 11:32 AM
    #42
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    I checked and it’s like what you said the top is extremely hot but the bottom is only warm
    SR-71A likes this.
  3. Apr 17, 2025 at 11:33 AM
    #43
    Neticstacoma
    No accessories is blocking the radiator, all stock
    Torspd[QUOTED] likes this.
  4. Apr 17, 2025 at 11:41 AM
    #44
    Neticstacoma
    So today I got a new after market rad and I was about to fix it on the car but unfortunately it has some differences so its not an exact match for the OEM one .. so i went to plan B like I said before earlier I had flushed the rad but the difference was so small but this time I took out the rad and cleaned it with a garden hose and some degreaser.. the rad was full of junk i can say, then I test the car again on the highway and there was about 48F difference in temperature (lower of course) like but I don’t think it is a fair comparison cus today I tested the car at 9:00 pm the weather is fairly cool not like when I drive on the highway at every day 2:00 pm
    What it’s the normal temperature rate on a highway?
  5. Apr 17, 2025 at 12:49 PM
    #45
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Are you saying you flushed the inside of the rad or externally between the fins? Either way at 180k and 17 years old experiencing radiator problems you're best off just replacing it. Just hop on rockauto and order the OEM Denso one for 130 bucks shipped to come in early next week and swap it out. Go to the nearest toyota dealer if you want to pay a bit more and get it probably same or next day. Return whatever aftermarket one that would need modification unless its a legitimate upgrade that you think is necessary.
  6. Apr 17, 2025 at 1:36 PM
    #46
    Neticstacoma
    Thanks yes I removed the rad and flushed it externally and internally
    I found the oem rad for 315$ with the dealership, i will check Rockauto like u said
  7. Apr 17, 2025 at 2:27 PM
    #47
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I tend to keep tabs on coolant temp since I have an 06 w/ the original head gaskets. I typically see 186F highway and around town this time of year. Pulling a small (1200#) trailer: 196F, driving through Death Valley in the middle of the summer: 209F.
    Still the original radiator but I did swap out the WP, tstat, fan clutch and coolant, 150Kmi.
  8. Apr 17, 2025 at 2:27 PM
    #48
    Neticstacoma
    what about other brands? Like: CSF, Spectra, FVP, UAC, Koyorad, OSC… ?
  9. Apr 17, 2025 at 2:32 PM
    #49
    Neticstacoma
    Thanks for the reply, I’ll verify tomorrow how much it will reach (temp) after the cleaning
  10. Apr 17, 2025 at 2:47 PM
    #50
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Within the normal temp range how accurate do you think the temp gauge is?
  11. Apr 17, 2025 at 8:51 PM
    #51
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Between 184~209F I couldn't see any difference in the needle position.
  12. Apr 18, 2025 at 5:42 AM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So a bunch of sludge like "junk" came out? Seems like you found the source of the problem.
    It would take multiple flushes to get that thoroughly cleaned, as well as the rest of the system.
    With the age, replace with oem, or better.
  13. Apr 21, 2025 at 6:38 AM
    #53
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    My order of choice would be Denso/OEM then probably koyorad and CSF if I needed an actual upgraded one since I've seen some threads about their all aluminum models. That price I mentioned was DENSO shipped from rockauto, at 1/3 the dealer price seems like a no brainer to me.
    SR-71A likes this.
  14. Apr 21, 2025 at 12:55 PM
    #54
    Neticstacoma
    Update
    So today I replaced the radiator with an after market for 70$ the OEM found expensive 315$ and I tested the car in city and it was actually very impressive I got max 155F compared to the older radiator I used to get 192F in the city
    some will say why u didn’t get the OEM from Rockauto the problem I live in Dubai so + the shipping costs it will be be +300$ and a big chance to receive it damaged
  15. Apr 21, 2025 at 9:29 PM
    #55
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Glad you got it going.
  16. Apr 22, 2025 at 3:15 AM
    #56
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Im happy everything worked out too, you should of mentioned you're in Dubai. Next time check here for OEM parts
    partsouq.com
  17. Apr 22, 2025 at 9:22 AM
    #57
    Neticstacoma
    thank u yes I know that website but recently it had a msg saying the below:
    (Unfortunately, we are currently not operational in the UAE domestic market. We apologize for any inconvenience this may cause.)
    thats why I went to a local store but definitely will keep checking it in the future
    thanks again
    joba27n[QUOTED] likes this.
  18. Apr 22, 2025 at 9:43 AM
    #58
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    155F is low, the thermostat should keep it in the 175-190 range.
    herecomesace, SR-71A and Jimmyh like this.
  19. Apr 22, 2025 at 1:34 PM
    #59
    Neticstacoma
    yea it’s too low but I don’t know whats the reason behind that, my thermostat opens at 82C
    Any ideas what could be the reason of that low temperature?
  20. Apr 22, 2025 at 1:47 PM
    #60
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pretty much all it can be is a thermostat that isn't fully closing or is opening too early as that is what regulates coolant temp.
