Coolant Update
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roadie_, May 9, 2025.
  1. May 9, 2025 at 8:19 AM
    Roadie_
    Roadie_ [OP] Active Member
    New to me '02 250k miles, previous post mentioned slight coolant loss and feared it was the head gasket. Then narrowed it down to potential Heater Core failure. Took it to the shop, they told me it should be fine and didn't notice any signs.
    However, each time I drive and park overnight, the reservoir looses about half an inch of coolant! It doesn't expand either, when checking it while hot. It seems to stay in the same place while running and after top off, but after I've driven it and parked overnight it has that slight loss.
    I'm perplexed! Any ideas what this could be? The only sign of loss I can discover is the truck smells like sweet coolant after running.
  2. May 9, 2025 at 10:54 AM
    TobsterStrudel
    TobsterStrudel Well-Known Member
    Florida
    '98 XtraCab 3.4 V6 M/T
    I would personally get a second opinion for the diagnosis.
  3. May 9, 2025 at 11:31 AM
    02hilux
    Planet: EARTH
    Honestly, if there’s an external leak, you will notice coolant dripping from where ever it is leaking from. You should not be able to smell anything sweet unless it is burning.
    A cracked heater core leak will be front to the firewall/floor board. Even if there’s a clamp failure from the hose to the core, the amount of pressure the cooling system is under will force coolant flow.
    Try idling later at night or early morning for 20-30 minutes with the heater on at full blast and check for damp carpet or drip.
    ControlCar and TobsterStrudel like this.
  4. May 9, 2025 at 11:54 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you're smelling coolant there's a leak somewhere
    Did the shop charge for their inspection? I'll bet they just don't want to do the heater core job..
  5. May 9, 2025 at 9:24 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    If coolant system working properly, it’s under pressure. This pressure will push coolant somewhere even when engine at rest……like 02hilux says….a leak somewhere
    “The truck smells like sweet coolant”
    can u elaborate on this statement?
    Inside cab
    Engine bay
    Exhaust
    koco likes this.
  6. May 10, 2025 at 12:12 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    My coolant reservoir was suddenly dry. Turns out it was the radiator needing replacement. No, they don’t necessarily show fluid on the ground. It weeps out slowly thru fine cracks. Your fluid loss is more regular and might have other causes.
  7. May 10, 2025 at 12:20 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    yeah on the crimp top radiators.....if it leaks at top, the fan blows it back onto the engine
    this is the only good quality I can think of about the pink coolant........makes it easier to find leaks
    .....built in leak dye
  8. May 10, 2025 at 3:59 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Same thing happened to me, crimps leaked and small cracks in the radiator plastic top.
    Always needed to refill reservoir. New rad fixed all that
  9. May 15, 2025 at 8:18 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    Mine ended up being the radiator. I couldnt see it leaking after i turned it off. Then it started leaking like crazy after a few days.
  10. May 16, 2025 at 11:15 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    You may be able to borrow a cooling system pressure tester from an auto parts store for free as a loaner tool to see if it holds pressure.
    Look for pink residue around the top and bottom edges of the radiator and around all of the hoses. It is also possible that the water pump is leaking from the weep hole, but look for the most simple places first.
    How much coolant have you added to the system already to top it off?
  11. May 17, 2025 at 4:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Check the weep hole on the water pump
    3JOH22A likes this.
  12. May 31, 2025 at 1:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    @Roadie_
    We like to hear results, not crickets
    Did you get it figured out?
    Roadie_[OP] likes this.
  13. Jun 3, 2025 at 12:12 PM
    Roadie_
    Lots going on the past few weeks, with lots of travel in the truck. Two 9hr trips, with a few additional 3hr trips in between without any major coolant loss! I might have lost about half an inch (measuring while cold) since this post and about 3k miles of driving.
    I believe the truck sat, or was very rarely driven since 2022. Dealership oil change sticker could attest to that. It displayed next service was set for Christmas day, 2022 or at the exact milage it was purchased at.
    Previous owner sold it to a "mechanic" who did the timing belt and a few other things. They most likely forgot to top off the reservoir, just as they forgot to plug back in one of the AC pressure plugs. What a nightmare that was to figure out, when it ended up just being a disconnected plug. Ice Cold AC now though!
    Anyways, no coolant smell after drives as it had when I purchased. Most likely was overspill from filling the radiator, and smell was coming from it burning on hot components. No leaks after any length of drives. Will continue to monitor the reservoir over time and continue to do some much needed maintenance.
