Coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eric J, Dec 3, 2016.
  1. Dec 3, 2016 at 2:13 PM
    Eric J
    Eric J [OP] Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Hello. My truck is low on coolant in the resivore and I was wondering if I need to put the Toyota special long life coolant in it or just regular 50/50 from autozone. Also is it bad to mix coolant?
  2. Dec 3, 2016 at 3:22 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Go get 50/50 pre diluted coolant from the dealership/eBay/Amazon and add coolant so it is about half way between the low and high marks. Don't mix other coolants.
  3. Dec 3, 2016 at 4:40 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    My question is is it wasn't that low a little while ago I know it is not leaking it's not overheating or showing any signs of a coolant leak where could it go
  4. Dec 3, 2016 at 4:44 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Not saying it is, but a leaking head gasket will make coolant disappear. Either into the oil, or combustion chamber. Take off radiator cap and start the engine, if it bubbles up it could be a head gasket leaking, check oil as well, if milky it also could be head gasket.
  5. Dec 3, 2016 at 4:50 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    distilled water:benchpress:
  6. Dec 3, 2016 at 5:35 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You might try a new radiator cap while you're at it. A weak old one will let a little coolant out.
  7. Dec 5, 2016 at 10:42 AM
    Backt
    Oregon
    It will evaporate over time it's just the nature of the beast. Just add some coolant and keep an eye on it. If it remains at a consistent level your golden if it's at the low mark in 3 weeks dig deeper
  8. Dec 5, 2016 at 11:04 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Coolant is one of those fluids where you should *not* mix different types. I agree if you just need a small amount for top-off, distilled water is OK. Anything more than a few cups, use coolant, not water.
  9. Dec 5, 2016 at 12:08 PM
    Eric J
    Ponte Vedra Beach
    To many to name
    Thanks man
