Cooler will not turn off - CFX3 7DZ
Discussion in 'Dometic' started by Coastgeo, Apr 25, 2024.
  1. Apr 25, 2024 at 1:16 PM
    Coastgeo
    Coastgeo [OP] New Member
    I have a CFX3 75DZ. The right side of the cooler will not turn off.
    The problem is with the right (large) side of the cooler which will not turn off and records a higher temperature than actual when in operation. There is no problem with the left side.
    With the cooler on the temperature on the right side will display a much higher temperature than what is measured. For example. If the cooler temperature is set for 45 degrees, the display will always show a temperature higher than 45 degrees and therefore the cooler will never turn off. The actual temperature within the cooler can drop to less than -5F depending on ambient temperature
    Has anybody else had this problem?
