Coolest temp sensor for gauges
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoYankee, Dec 15, 2017.
  1. Dec 15, 2017 at 4:35 PM
    TacoYankee
    TacoYankee [OP] Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    2004 Tacoma with the 3.4. Trying to find the single wire temp sensor for the coolant temp gauge. Gauge reads above the H on start up when motor is cold. Dealer claims to have replaced it and the gauge when I bought it used a couple months back. It had the same issue, that’s why those parts were replaced. Worked fine for a couple months, now acting up again. I’d like to find it so I can test it myself before I take it back. Only thing I found was through Haynes, the diagram looks like a kid in pre-K drew it. Points somewhere on the driver side rear of the motor? Any ideas?
  2. Dec 16, 2017 at 5:30 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    The coolant temperature SENDER is the one that outputs to the dash gauge. The coolant temperature SENSOR outputs to the ECM.
    On most vehicles the SENDER is located at the coolant output hose going into the radiator. I believe this is where it is on the 5VZ, it is definitely in that location on the 3RZ.
  3. Dec 16, 2017 at 6:34 AM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    The sender should still only have one wire going to it right? Since I’m not getting a trouble code, the sensor should be good. I’ve located what I suspect to be the sensor near the upper hose inlet. It has two wires going to it.
  4. Dec 16, 2017 at 3:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    So what you’re saying is that the dealer just started replacing parts that didn’t turn out to be the actual problem?
    You don’t say...
    OneWheelPeel likes this.
  5. Dec 16, 2017 at 3:40 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Yeah, shocking. Found the sender, took me some time.
    Just in case anyone else needs to know, it’s on the backside of the intake manifold near the center of the firewall. Single wire connector. It’s hidden under a hose; like a heater hose I suspect.
  6. Dec 21, 2017 at 12:44 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Could be a bad ground at the gauge.
    If you ground the wire at the engine temp sender the temp gauge should go to hot. (Only do this briefly or it could ruin the gauge)
    Test the coolant temp with an infrared sensor by pointing it at various places, (radiator, thermostat housing) so you know what true normal is.
