Cooling entertainment center
Discussion in 'Technology' started by 95 taco, Aug 5, 2015.
  1. Aug 5, 2015 at 9:10 PM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    adding a fan to the entertainment center, I got one AC fan off of Amazon, it doesn't move tons of air but it's better than nothing.
    My question is do I set it up as an inlet fan or vent fan? It's going to go on the back wall of the Cabinet, behind the DVR (left side) because the DVR is always on.
    Here's a pic of how everything is laid out.
    DVR is always on, DvD/surround sound is on ~30% of the time, and the PS3 and Wii rarely get used.
    I try to keep the front "door" open but we babysit a 2 year old who likes to close it so it's not always open, it has a solid glass window but if I can find it I will swap the glass out for mesh so everything breathes better.
  2. Aug 5, 2015 at 9:20 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Exhaust..... DVD prolly has a very small 40mm fan already exhausting it, I know ours does, so get that air OUT.
    U can usually power a small case fan off of the USB port on the DVR if if has one.....we did
    Reciever prolly has heatsink and no fan right?
    Heat will rise on its own, so again exhaust that shit out.
    I got lucky and my onkyo rec has a large sink and a 100mm fan on if.
  3. Aug 5, 2015 at 9:37 PM
    95 taco
    Yep, DVD has a 40mm on the back, DVR has just a heatsink with 5V 500mA USB on the back, it also has a 110 plug on the back.
    Ok, I will set it up as an exhaust fan and see how the temps go, if it still is warm in the cabinet I'll get a 2nd fan and put in as an input fan.
  4. Aug 7, 2015 at 10:05 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Just cut couple of holes in the back. Or cut a bit one and cover it with the window screen to keep the dust out. No need for fans. It will just add noise. I would also add some spacers between devices sitting on top of each other. Honestly, though, I would not worry about this stuff getting too hot.
    I have all my equipment in the closet, up at the ceiling and it gets hot there. Haven't had any issues and there are alot of things there....
    Receiver (gets hot... or very hot when running 2 HDMI zones at the same time),
    Cable Box (gets really hot),
    AppleTV,
    Amazon FireTV,
    HDMI Transmitter (powered),
    S/PDIF Transmitter (powered),
    Firewall (gets really hot),
    Synology DS412 network storage (gets really hot),
    Cable modem,
    Network switch,
    PDU,
    UPS
  5. Aug 7, 2015 at 11:50 AM
    95 taco
    You also have a lot more air volume surrounding the equipment.
    I'm gonna cut 2 holes, one for an inlet and one for the exhaust fan and I think it'll stay a lot cooler.
  6. Aug 13, 2015 at 8:40 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I also agree with using it as an exhaust. You don't want a fan blowing dirt and pet hair into that area.
    Justus likes this.
  7. Sep 9, 2015 at 7:49 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ..i'd think cutting a decent sized hole in the rear backboard of the cabinet should be sufficient for what you've got in there... but if you want a fan back there, it would seem logical to configure it for exhaust, ...that way the warmed air isn't being blown across the electronic devices front-to-back...
    Justus likes this.
  8. Sep 9, 2015 at 7:54 PM
    95 taco
    Got the fan installed several weeks ago, lots cooler inside with just the hole for the exhaust fan.
    Temp is ~15 degrees cooler on average.
    T4RFTMFW and Justus like this.
  9. Sep 9, 2015 at 8:00 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I have a similar cabinet with more equipment then that running and it used to get pretty hot until I cut most of the back off. I would just open up the rear and not worry about fans or leaving the door open.
  10. Sep 9, 2015 at 8:06 PM
    wileyC
    Centerville, OH
    just curious, ..are you running from some kind of fan control device, ...I.e so it switches on/off automatically based on some temperature sensor/reading?..
  11. Sep 9, 2015 at 8:12 PM
    95 taco
    No, I'd like to but when I ordered the stuff I was trying to spend as little as possible.
