Cooling Fan Bracket
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jazzalou1, Mar 29, 2020.
  1. Apr 1, 2020 at 3:35 PM
    Jazzalou1
    Jazzalou1 [OP] Member
    Greg
    2003 toyota tacoma 4wd double cab
    plow
    Just got finished, much easier with radiator and shroud removed. A lot more room to work. Turns out my AC Compressor was also part of the problem. So off with the belt for now. Rest of the job took about 4-5hrs from start to finish. One quick note, does anyone have trouble with the alternator adjustment bolt, mine is seized again. This will be the 3rd one I’ve bought and all were from dealer, any thoughts? To me it’s a simple design but crappy metal bolts I guess too.
  2. Apr 2, 2020 at 8:41 AM
    Saiko
    Saiko Well-Known Member
    Saiko
    Chicago
    00 2RZ w59 2wd
    THANK YOU, jeff i guess we do learn something new everyday, iam mora of a 2.4l type :angrygirl::annoyed:
  3. Apr 2, 2020 at 9:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did this not seize and rip through your whole engine compartment tearing things up?
    i heard it has happened to others
    was there a noise before it went so you know what was happening
    Black97v6MT likes this.
  4. Apr 18, 2020 at 1:50 PM
    Jazzalou1
    Greg
    plow
    Ya sounds like a cross between no power steering fluid in power steering pump and a jet plane. Did quiet down once u start moving but was loud very loud at idle. I only went 2 days once I heard it
  5. Mar 22, 2025 at 6:37 AM
    1997tacomav6
    Denver
    I know this is an old thread but whoa is the actual torque for the fan bracket bolts?
  6. Mar 22, 2025 at 6:43 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Is it not spec'd in the diagrams in the FSM?
  7. Mar 22, 2025 at 8:04 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
