Cooling system flush: distilled water how many times?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jun 29, 2021.
  1. Jun 29, 2021 at 12:35 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    If you had a 1st gen with an unknown maintenance history, but no overt issues with the cooling system, how many times would you run distilled water through the system before adding fresh coolant?
  2. Jun 29, 2021 at 12:36 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    None, if you are flushing just use hose water.
  3. Jun 29, 2021 at 12:37 PM
    crackedmirror
    Though regular water was a no-no
  4. Jun 29, 2021 at 12:38 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you are flushing it out at the end then why should it matter.
  5. Jun 29, 2021 at 12:39 PM
    crackedmirror
    I've read that it introduces minerals that solidify over time. Not sure how true but it's what I've read.
  6. Jun 29, 2021 at 12:41 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    There won't be any damage if you use it to flush and then fill with coolant and distilled water. I'm sure there are tons of people who use regular water and coolant with no issues.
  7. Jun 29, 2021 at 12:44 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I would say most of the damage comes from cars that sit a lot and also are never serviced or changed. Same with oil.
    crackedmirror[OP] likes this.
  8. Jun 29, 2021 at 12:46 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Best if you can find the block drain plug, flush and when adding coolant mix with distilled water only. Toyota or Pentosin red is usually 50/50 mix. I'd suggest a new thermostat if you are flushing. OEM only.
  9. Jun 29, 2021 at 1:03 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Fill with distilled water and drain 3 times usually yeilds clear water.
    Add 1 gal Red full strength after last drain gives you 50/50 mix because a gal stays in block after draining radiator.
    crackedmirror[OP] and RysiuM like this.
